  New Posts New Posts RSS Feed: Picked up 179 today
Topic ClosedPicked up 179 today
NAP1947 View Drop Down
Direct Link To This Post Topic: Picked up 179 today
    Posted: 11 May 2018 at 5:50pm
we got our 179 today, went through inspection and instruction session.  The pod is clean and everything works, we have lots to learn.
One thing I identified during the inspection is the tank dumps appear to be backward, the grey water has the large full size drain pipe but the black water has a pipe that is about half the diameter.  Have not measured yet but the grey is about 4” diameter and the black about 2”.  That is reversed from what I experienced with our motor homes.
Anyone else have this situation?  Is it normal?  My dealer was not sure but agreed it seems backwards.
Susan and Norm
2016 Venza, V6 factory tow
2018 RP179
Direct Link To This Post Posted: 11 May 2018 at 6:02pm
That's interesting. Does the gray 4 inch go to the black tank. I know stupid question.
crankster78 View Drop Down
Direct Link To This Post Posted: 11 May 2018 at 7:08pm
The grey water tank is at the back and the black water towards the front.  Mine have decals above them and having dumped them for 3 years know where they are.
Crankster78
Crankster 78 R-179 2015
Direct Link To This Post Posted: 11 May 2018 at 7:25pm
Thanks Crankster, but what does that have to do with the OP?
Direct Link To This Post Posted: 11 May 2018 at 8:09pm
I think if your large pipe, believe 3" does not go to black tank, you have a issue, the smaller drain should in fact go to the gray tank. My 178 is the same as Cranster says, theblack tank is foraward, gray tank is more rear, my freshwater tank is at the aft.
Direct Link To This Post Posted: 11 May 2018 at 9:33pm
Unless FR has made some major changes in the 179, the tank closest to the hitch (translucent white) is the fresh water tank. Behind that, in front of the axle and underneath the wet bath is the black tank. Behind the axle is the gray tank. It would make no sense whatsoever to have the black tank in the back. How would the toilet flush into it?
We have the 2016 RP179.
Direct Link To This Post Posted: 12 May 2018 at 6:11am
Thank you, crawled under last night to get a better look.  Water tank is closest to hitch, then black under bathroom and grey at the rear near the kitchen.  The labels on the side are placed wrong.
Now the fun begins.
Susan and Norm
2018 RP179
Wood River Pod View Drop Down
Direct Link To This Post Posted: 12 May 2018 at 10:32am
Our pull handle to open the drain valve on the gray tank is gray and the black tank is black.
Thanks
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
TheBum View Drop Down
Direct Link To This Post Posted: 14 May 2018 at 2:46pm
It's strange that they went with a smaller diameter drain for the gray tank. On our 2016 179, both drains are 4".
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 14 May 2018 at 3:27pm
I have a 3" black water drain, and a smaller 2" or less gray drain. I think biggest drain is 3", cover is close to 4".
