LED harsh color change |
gkooris
Groupie Joined: 30 Oct 2014 Location: Connecticut Online Status: Offline Posts: 40 |
Topic: LED harsh color change Posted: 20 May 2015 at 3:42pm |
We love the LED lights, but found the intense blue / white a little harsh. I got a hold of some very light colored pale yellow theater gel, and lined my lights with it. Incredible difference. Light is so much more natural. You can get this stuff at theater supply houses online, and it's meant to be used in lights that generate tremendous heat, so using it in the RV LED lights is no problem.
Geoff in CT
When in doubt, go strong and wrong
Posted: 20 May 2015 at 4:46pm |
Good tip. The old fixtures that were not LED from the factory, gave us lots of options because we could up grade or downgrade LED count and color. Now that LED is standard, your kind of stuck with what FR provides.
Posted: 20 May 2015 at 7:54pm |
Moved to the podmod section.
It is great that FR now installs LEDs by default, but I guess they need to give you a color choice.
im20agn
Newbie Joined: 01 Jun 2015 Location: Tacoma Online Status: Offline Posts: 13 |
Posted: 21 Jul 2015 at 12:29pm |
How did you put the theatre gel into the light lens? I tried but the sheet krinkles and Im not sure how to bond it in.
gkooris
Posted: 21 Jul 2015 at 12:52pm |
I just sort of formed it and cut some slits. It's time consuming. Even with the overlaps it works pretty well
gkooris
Posted: 21 Jul 2015 at 1:00pm |
Takes a while to cut and slit. Time consuming as well. I have overlaps in mine, but it works.
