  New Posts New Posts RSS Feed: Turning the radio off... Completely!
Topic ClosedTurning the radio off... Completely!
Inge View Drop Down
Direct Link To This Post Topic: Turning the radio off... Completely!
    Posted: 30 Jul 2014 at 3:13pm
Does anyone have magic button combination handy that turns of the
Radio completely? I mean really off, no blue light shining on us like the full
Moon during the night :) The only way we could figure out is removing the fuse.
We've got the r-pod 182g and I don't know right now what brand the radio is. Just thought
Others here must have had this issue as well.
ahefner View Drop Down
Direct Link To This Post Posted: 30 Jul 2014 at 3:24pm
I found a button on the radio that turns the backlight off when not in use on the radio. The brightness button next to the LCD may have been the one. Otherwise it was an option in the menu maybe. Now if I can only find the one that does the TV power off light.
2014 rPod 178
2014 Toyota Tundra 5.7
Direct Link To This Post Posted: 30 Jul 2014 at 3:46pm
Like ahefner, on my Jensen it's here:
Then just power it off.
Direct Link To This Post Posted: 30 Jul 2014 at 4:35pm
That was the button I was thinking of. My TV has a bright blue light on it when its not powered on. Turns off when the TV is on however. I found it more annoying the radio. Anyone know if it can be turned off. Thinking about covering it with a small piece of electrical tape.
2014 rPod 178
Direct Link To This Post Posted: 30 Jul 2014 at 9:44pm
With my TV/radio combo, I just unplug it in the cabinet above it.
Inge View Drop Down
Direct Link To This Post Posted: 14 Aug 2014 at 11:02pm
Here is a picture of our radio. We've investigated, searched, tried each button. The display didn't turn off.
Does anyone know what to do (other then pulling the fuse each time)?
"Bommel" - r-pod 182 G
" Franzi"   - Toyota Tundra 2007
http://blog.picturingtheamericas.com
Inge View Drop Down
Direct Link To This Post Posted: 14 Aug 2014 at 11:07pm
HA! Now that I saw the picture in soooo big, I finally saw the model of the radio and found the manual online here and this description:
Liquid Crystal Display (LCD)
The liquid crystal display (LCD) panel (4) displays the frequency, time and activated functions.
To adjust the brightness of the LCD, press and hold the VOL control to access the user menu.
Press the VOL control to step through the menu options. Rotate the VOL control to adjust the
LCD brightness from “LIGHT 1” (brightest) to “LIGHT 3” (least bright).
Will try that next.  Smile
Direct Link To This Post Posted: 15 Aug 2014 at 11:52am
 Inge thank you, I have the same radio and wanted the same information on how to turn off or lower the brightness of the display light. I will try to follow the instructions and see what happens, hope it works. Smile I went out to the camper and the instructions worked. Ours was set at 2 and I adjusted it to number 1. I would of liked to be able to turn it completely off but that doesn't seem to be possible unless you disconnect the power. One is better than two. Smile
2014 Ram 1500 Quad cab
