Water heater |
cody91
Senior Member Joined: 12 Feb 2014 Online Status: Offline Posts: 184 |
Topic: Water heater Posted: 08 Apr 2014 at 2:06pm |
Just a newbie question on the Rpod water heater.
Does the water heater work when connected to city water or does it only work when using the fresh water tank or both? Thanks.
Leo B
Posted: 08 Apr 2014 at 2:21pm |
When connected to city water just make sure you connect to the water first so there is water in the heater tank, then turn the switch on and it will work.
wingnut2312
Senior Member Joined: 25 Aug 2013 Location: MI Online Status: Offline Posts: 231 |
Posted: 08 Apr 2014 at 3:14pm |
Yup. Run the hot water tap until water flows through. Once flowing, the hot water tank is full and you can turn the heater on. DO NOT TURN IT ON BEFORE FULL!! You'll kill the element.
2014 rpod 182G
Ford Expedition |
Posted: 08 Apr 2014 at 3:19pm |
You'll also lose 6 gallons from your fresh water tank if you don't fill the water heater at home first. That's a big hit if you want the water to last over a weekend.
wingnut2312
Posted: 08 Apr 2014 at 3:54pm |
Good point. Never even considered that...
2014 rpod 182G
Ford Expedition |
