  New Posts New Posts RSS Feed: Coleman Ac Units
Topic ClosedColeman Ac Units
Pod-a-terre View Drop Down
Direct Link To This Post Topic: Coleman Ac Units
    Posted: 17 Dec 2013 at 8:11am
Is there any way to have Forest River install a Coleman 9200 Polar Cub AC on a 178 or the new 179. The thing I like is that a 2000 watt generator will run it. OR would one order the unit pre wired and have the dealer install one?
I would think that the 9200 would cool the unit ok; any thoughts or comments would be most welcome,
John
John Kris "Lady Sarah" our Golden
Aiken SC
kymooses View Drop Down
Direct Link To This Post Posted: 17 Dec 2013 at 9:11am
FR won't add a different unit for you but you could order without an AC and then have your dealer add the coleman.
Direct Link To This Post Posted: 17 Dec 2013 at 10:02am
Many have found over the years that with a "hard start mod" the 2000i will start and run the Dometic just fine.
But if you wanted, as Travis said, just order without, and add what you want.
I honestly think a smaller a/c would be better. I think the 13.5 has a tendency to "over cool" and cycles improperly because of that. A smaller unit would be better because it would run in longer, less "powerful" cycles..
Kickstart View Drop Down
Direct Link To This Post Posted: 17 Dec 2013 at 11:37am
John, I'm probably one of the few with a Polar Cub on their Pod. When we bought our 175 in 2010, it came wired for air, but with no unit. We live in Western Washington and seldom need air, so that was no problem. We're planning an extended trip next year to the S/W and East, so last year we had a Polar Cub installed.
We've had both Coleman and Dometic units in the past, and always been happier with Coleman units. The PC cools the Pod nicely, but not overly quickly. It is quieter than I remember our Dometics to have been. Our PC is not wired into the Pod thermostat. We use the ceiling control, which is no problem, as that's what we're used to. Due to the length of the PC and the Pod's roofline, make sure the PC is installed with the foam rear brace that is so common with many A/C installs.
The Polar Cub has run fine with our Yamaha EF2000IS up to now. We haven't dry camped @ much elevation or high temperatures as of yet while using the PC/Yamaha combo. I think the PC comes with a hard start capacitor already installed--I've been wrong before. In any case, the PC draws less juice that the 13.5 btu units. Up to now, we're well satisfied with the Polar Cub
'12 Toyota Tundra
'05 Sportster (half a Harley)
Retired-We're on Beach Time!
Direct Link To This Post Posted: 17 Dec 2013 at 1:16pm
Thanks for all the comments and advice on the AC question. May just stay w/ FR 13.5 and see if hard start will work if not bite the bullet and get 2 Hondas.
John
Aiken SC
Direct Link To This Post Posted: 17 Dec 2013 at 8:27pm
The Dometic will run on a Yamaha EF2400, which is still moveable by one person (but easier with 2 people).  Might be cheaper than 2 of the Hondas.
I'm still considering switching to the Polar Cub before our next big trip this summer.  3 1/2 weeks with the Dometic blaring overhead wasn't fun last summer.
Thinker View Drop Down
Direct Link To This Post Posted: 20 Dec 2013 at 3:53pm
Originally posted by Pod-a-terre
Thanks for all the comments and advice on the AC question. May just stay w/ FR 13.5 and see if hard start will work if not bite the bullet and get 2 Hondas.John
I have two Hondas, I normally leave one home. Does fine.
