  New Posts New Posts RSS Feed: Under the Pod
Topic ClosedUnder the Pod
mountain mist View Drop Down
Direct Link To This Post Topic: Under the Pod
    Posted: 03 Nov 2010 at 8:52pm
I was reading where you might need to protect any plumbing that is underneath the Pod.
HOW?
How about black plastic bags stuffed with newspaper and stuffed under the Pod. Is that insaneStar
'11 Forest River r.pod 171
'10 Ford Edge
ESCAPE POD
Trudi and Austin mini-schnauzers
change here, Trudi has gone, Austin now has a small black schnauzer buddy, Bentley
this_is_nascar View Drop Down
Direct Link To This Post Posted: 04 Nov 2010 at 8:06am
What are you looking to accomplish by "protecting the plumbing that is underneath"?  Are you looking to use the R-Pod in the freezing tempatures or something?
"Ray & Connie"
- 2017 R-Pod RP-180
rpodcamper.com View Drop Down
Direct Link To This Post Posted: 04 Nov 2010 at 3:43pm
During the cold if they are empty you are fine.  If you are camping longer term and it is cold outside you need to worry about freezing.  I have camped with mine in the winter and only one time did I freeze up.
Direct Link To This Post Posted: 04 Nov 2010 at 5:04pm
As long as you've fully winterized you don't need to do anything underneath.  I don't recommend using your water system during the winter.  There are ways to keep things from freezing (heat tape w/insulation, boxing in the underside) but its far easier to just keep jugs of water inside for handwashing, cooking and tooth brushing.  Most campgrounds don't offer water service during the winter since the same special methods must be used to keep the faucet from freezing.  And its impossible to protect the underside while driving down the road below freezing unless you make some major modifications.
Folornhope View Drop Down
Direct Link To This Post Posted: 01 Dec 2010 at 12:46pm
If I remember right, Home Depot or Lowes will sell some foam insulation that fits around pipes.  Don't know if that will do what you need or not.
