  New Posts New Posts RSS Feed: fridge temp
Topic Closedfridge temp
hogone View Drop Down
Direct Link To This Post Topic: fridge temp
    Posted: 13 Aug 2016 at 8:08am
can you guys simplify thisConfused  i recently asked this exact question regarding fans, mine don't seem to come on in any temperature.  hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
JandL View Drop Down
Direct Link To This Post Posted: 20 Jun 2016 at 1:31pm
Here are some pictures of the switch and fan on my trailer. The switch clips on to the condenser tube and it is set to open at 70C (158F) and close at ?. All are accessed thru the upper vent cover on the outside of the trailer
vent cover remover
Temp switch
Fans
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
osage View Drop Down
Direct Link To This Post Posted: 20 Jun 2016 at 12:51pm
outside top opening
Direct Link To This Post Posted: 20 Jun 2016 at 10:52am
from the outside top opening
this_is_nascar View Drop Down
Direct Link To This Post Posted: 20 Jun 2016 at 6:14am
I only recall seeing 1 fan on mine.  What temp should it come on?
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 19 Jun 2016 at 9:52pm
This bears emphasizing - see the first article linked by JandL, the first diagram.  You'll see a baffle shown in green, but it isn't discussed.  You must make sure there is a good baffle between the upper and lower sections.  The factory baffle is always flimsy so it falls down, or doesn't seal right.  It is supposed to force air flow over the black tubing (absorber).
The 2nd article (briefly) discusses baffles about half-way down.
johnmaci View Drop Down
Direct Link To This Post Posted: 19 Jun 2016 at 1:51pm
Interesting articles. Ill have to see how mine is set up.....
Direct Link To This Post Posted: 19 Jun 2016 at 11:40am
Here are some articles on cooling fans and different mounting locations. I have had no problem with my refrigerator fans mounting location and they only come on whens its warm outside
https://www.arprv.com/rv-fridge-fan.php
http://www.fridge-and-solar.net/fridge_vent.htm
JandL
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 19 Jun 2016 at 10:56am
Thx....
Any idea why the fans were not coming on due to the location?
I wonder if the thermal switch not close enough to the heat source, or was it too close to the fans and prematurely shutting down due to incorrect readings?
This must be is a common issue.......
Direct Link To This Post Posted: 19 Jun 2016 at 10:47am
Was this accessible from the outside or did you have to pull out the fridge? Any before/after pictures?
I posted a picture of the fans in another post. You will need a mirror to see the fans, and if you follow the red wire taped to the back side of the refrigerator it will end at the switch. You need to remove the upper vent cover to see the switch.
http://www.rpod-owners.com/forum_posts.asp?TID=8153
JandL
2012 177
2 Paynes in a Pod
