  New Posts New Posts RSS Feed: A few more wishes
Topic ClosedA few more wishes
Unclewillis View Drop Down
Direct Link To This Post Topic: A few more wishes
    Posted: 12 Jun 2015 at 10:52am
Electric water heater switch inside on the control panel.
black tank flush port on the slide side of the camper
Daddy, Mommy and Daughter.
Rpod 176T 2015
Nick:
ouR-pod
Direct Link To This Post Posted: 12 Jan 2016 at 9:56pm
single drain for both black and gray tank
Rpod 176T 2015
Nick:
ouR-pod
Direct Link To This Post Posted: 13 Jan 2016 at 7:29am
Unfortunately a single drain is impossible for the models with a slide.
kymooses View Drop Down
Direct Link To This Post Posted: 13 Jan 2016 at 10:36am
Some slide models have a single drain, mine does.  Depends on the floorplan and where the tanks can actually fit.
Direct Link To This Post Posted: 13 Jan 2016 at 10:38am
The HRE models have the black tank flush on the slide side typically.  But one reason for it not to be there is for it not to ever be confused with the city water inlet and you ever accidentally cross contaminating.
As far as a switch inside, some have wired up a switch for theirs inside.
Direct Link To This Post Posted: 13 Jan 2016 at 1:09pm
Easy solution for the WH switch is to use the circuit breaker. Not quite as convenient, but a lot easier than going outside.
kymooses, I thought all of the slides had the tanks on either side of the slide. My bad!
