Total n00b in FL buying a used RP-171, need advice |
Post Reply | Page <12 |
JohnBG
Senior Member Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Topic: Total n00b in FL buying a used RP-171, need advice Posted: 03 Jun 2015 at 11:06am |
My base-model Ridgeline RT doesn't come standard with the 7-pin trailer connector and control box, so I ordered this kit: http://www.handa-accessories.com/ridgeline/09harness.pdf. The fancier model RTL Ridgelines come form the factory with the 7-pin harness and receptacle. I also ordered a Tekonsha Prodigy P3 brake controller with the wiring adapter that plugs directly into the Honda control box from eTrailer. So hopefully between the two I will have everything I need for the lights and brakes. The Ridgelines come standard with a transmission cooler, but no temp gauge, just an "idiot light" on the dash to indicate overheat. I'll have to look into the Interceptor unit you mentioned. I have no idea what model WDH the seller has. I will call them and try to find out and let you know.
Posted: 03 Jun 2015 at 1:06pm |
We both posted at the same time, Charlie, people are going to think we are the same person.
Ok, so Honda has a specialty connector at the rear of the vehicle, I see now. That means all of the wiring is there. If you want to save some money you could map out which pins go to which pins on the Bargeman, get the part numbers off of the relays, then return the kit. Buy the $5 Bargeman and hook up the wires manually using the pinouts you copied. Get the relays from a local auto parts store. Compared to the ScanGuage and other options the Interceptor is pricey. What I liked about it is you don't need to mess with setup codes. You buy one specific to your vehicle brand.
CharlieM
Posted: 03 Jun 2015 at 2:17pm |
Pod4Two
Senior Member Joined: 04 Dec 2014 Location: DFW Texas Online Status: Offline Posts: 120 |
Posted: 03 Jun 2015 at 6:31pm |
Welcome
Ina & Philip Kennedy
2011 -177 2014 GMC Z71 4x4 |
Podster
Posted: 22 Aug 2015 at 9:10am |
It was a while ago, but when I started considering trans temp someone here on the forum suggested a OBD II scan gauge and whoever it was, (searched but cannot find) I just want to say THANK YOU! I was totally clueless about such devices. I'm aware of the diagnostics port of course, but had no idea you could use an after market interface to tap all of the data the ecm holds and use it to monitor TV systems. So, after considering many other options I purchased the scan gauge II and it WORKS! Apparently the Ranger has a Trans Temp senor used to activate a solenoid after reaching temp to allow fluid to flow through the cooler and the scan gauge picks up the temp through the X-Gauge feature...solves so many problems trying to add an after market trans gauge, not to mention all of the whistles and bells that come with it. Thanks again! This forum rocks!
Cliff & Raelynn
Posted: 23 Aug 2015 at 8:48pm |
Glad you got it working. It is odd that the manufacturers just don't put all that info on the dash, even if only on the digital readout.
