Total n00b in FL buying a used RP-171, need advice
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6354
Printed Date: 21 May 2025 at 11:45am
Topic: Total n00b in FL buying a used RP-171, need advice
Posted By: JohnBG
Subject: Total n00b in FL buying a used RP-171, need advice
Date Posted: 02 Jun 2015 at 2:57pm
Clueless n00b taking the plunge alert...
Posted once here before looking for info. on R-Pods and took the plunge and bought a used 2010 RP-171 which I am picking up this weekend from a private seller about an hour away.
I am so excited, but a little nervous as my wife and I have exactly zero camping experience.
We've been thinking about buying a travel trailer and looking on and off for over a year or two.  We love the R-Pod concept as it is small, simple and we only have a 6-cyl Honda Ridgeline to tow it with.  We fell in love with a new RP-179 at a dealer but didn't want years of payments, so I started looking for used ones and this RP-171 came along and looks like a good starter unit and we can afford to pay ca$h for it which is nice.  Maybe in the future we'll upgrade to a bigger one.
I need to install a 7-pin harness and a brake controller on the Ridgeline, any suggestions on what brake controller to use?
Need to save up and start looking for an R-Dome to attach to it?  Where is the best place to get that?  Is there someplace online or do I need to go to a dealer and pay dealer price?
Also looking for advice on how to setup and maintain the camper.  I have no experience on filling water tanks, hookups, and draining the gray/black water tanks.
Any advice you can throw to a n00b, I'm listening.  I'm sure I'll have a ton more questions in the future.
Thanks in advance for all your help.
John
Posted By: CharlieM
Date Posted: 02 Jun 2015 at 5:10pm
Greetings, John, and welcome to our forum. You have found the best and friendliest source of Rpod info on the internet. Starting with the 171 will give you an inexpensive way to find out what you need and want. Many owners remain well satisfied with 171/172 models for years.
I'll comment on a few of your questions, but the best approach is to just start reading threads here. Your questions are similar to any new owner's and all have been answered here many times over. The only problem is finding the material. Many answers are available at T
echntrek's instruction manual.
http://www.rpod-owners.com/forum_posts.asp?TID=1723 - http://www.rpod-owners.com/forum_posts.asp?TID=1723
You need a seven pin Bergman connector installed on you Ridgeline.  Most owners here use Tekonsha brake controllers. I'm partial to the P3 because it is proportional, self leveling, has a full alphanumeric display, and is very easy to install and use.
Your Ridgelne comes prewired for a brake controller.
http://www.amazon.com/TEKONSHA-CONTROL-HARNESS-RIDGELINE-CONTROLLER/dp/B007O5GXSW/ref=sr_1_1?ie=UTF8&qid=1433277867&sr=8-1&keywords=tekonsha+p3+honda - http://www.amazon.com/TEKONSHA-CONTROL-HARNESS-RIDGELINE-CONTROLLER/dp/B007O5GXSW/ref=sr_1_1?ie=UTF8&qid=1433277867&sr=8-1&keywords=tekonsha+p3+honda
The Rdome is very handy and will almost double your available space. It takes some practice to put it up, but it becomes very easy if you have two people. I would scan the Campers Flea Market section of this form and/or place an ad there.  Be sure to specify you year and model (2010 Rp171) because there are several versions of the Rdome. Your 171 will require the small Rdome. The early Rpods had a smaller track for attachment of the Rdome so make sure you get the right one. If you can't find one for sale you can buy one from Forest River, but they are expensive.
You will want a weight distribution hitch (WDH) for your comfort and peace of mind. I towed an RP172 with a Pilot for a year and never had a problem. The Fastway E2 is popular and is ideal for you combination.
http://www.amazon.com/Fastway-94-00-0600-Round-Weight-Distribution/dp/B0071L3H2E/ref=sr_1_4?ie=UTF8&qid=1433279096&sr=8-4&keywords=fastway+e2 - http://www.amazon.com/Fastway-94-00-0600-Round-Weight-Distribution/dp/B0071L3H2E/ref=sr_1_4?ie=UTF8&qid=1433279096&sr=8-4&keywords=fastway+e2
The rest of the info comes from reading this forum, experience, and asking questions. There's no such thing as a dumb question. Just dumb answers and we try to minimize those. Welcome to Podville. You'll love it.
Posted By: JohnBG
Date Posted: 02 Jun 2015 at 7:09pm
Thanks Charlie!
Yup, I have been surfing the forums here and gleaned some good information.
I was reading my Honda Ridgeline Owner's Manual (Yup, I'm an engineer who actually reads the manuals) and it was saying that Honda doesn't recommend the weight distributing hitch and says the following on page 297:  A weight distributing hitch is not recommended for use with your vehicle, as an improperly adjusted weight distributing hitch may reduce handling, stability, and braking.
So do I really need the weight distributing hitch?  The seller that I am buying the camper from has a used one I can buy from them for $150.  Do I need to pop for that?
Did you need any sway bars with your 172 and Pilot?
Aside from that, it appears that the Ridgeline has enough towing power at 5,000 lb. with 600 lb. tongue weight (assuming only two passengers).  According to the 2010 R-Pod brochure, the RP-171 has a dry weight of 2121 lb.,  a hitch weight of 181 lbs. plus the optional air conditioner at 97 lb. and the convection microwave at 51 lb., so unloaded it will weigh in at about 2450 lb. dry.  Even if I figure in a few hundred pounds for some water and gear, if I did the math right, it looks like I'm not anywhere near overloading the Ridgeline.
I checked out the P3 controller and I think I will go with that.  My model Ridgeline (RT base model) doesn't include the 7-pin receptacle and controller (standard only on the RTL and RTX models) so I need to buy the Honda kit with the relays control box and install that with the brake controller.  Does the P3 controller need to be installed at or near level horizontally?  I was looking at installing it below the dash on the console near the gas pedal.  That would make it almost vertical or at least 60-70 degrees from horizontal.
Thanks for the heads-up on the R-Dome, I didn't know there were different sizes and tracks.  Good info.!
I am so excited to be getting an R-Pod and going camping, but there's a lot of stuff I don't know (or even don't know that I don't know) but hopefully I can pick up some knowledge here.  It's going to be an adventure!!!
Posted By: techntrek
Date Posted: 02 Jun 2015 at 7:50pm
I would still recommend a WDH.  After we moved from a minivan to a Suburban I tried towing once w/o our WDH in place and immediately put it back on for the trip home.  It improves the ride quality since it is basically adding an extra suspension system into the mix.  Some WDHs include sway control some don't.  If the one you are offered doesn't you can pick up a cheap sway bar.  Just remember to disengage the sway bar (not the WDH) when you back up.
Posted By: CharlieM
Date Posted: 02 Jun 2015 at 8:38pm
John,
My Pilot had the same note re WDH and I used the E2 on it for a year, including a 5000+ mile trip from FL to the Colorado mountain passes. No problems. Honda is correct in saying an improperly adjusted WDH can cause problems. In fact it can be downright dangerous, but that is true of any WDH on any tow vehicle (TV). My 172 was advertised at ~2200# and came in at ~2750# with batteries and propane.
Still well within your 5000# rating so no problem. Your setup falls into my "You may not need WDH, but you'll want  WDH". The WDH smooths out the bouncing and porpoising from dips and bumps. If you read the forum, searching on WDH, you'll find lots of folks that tried without, but later added it. Even F150 and Suburban drivers go back and add WDH. BTW there should be a yellow sticker on the 171 stating the exact weight as it left the factory. To that you have to add battery(s) and propane tank (s) for an "empty" weight.
The E2 I used (and still use) provided both weight distribution and sway control. I do not recomment the friction type swayy control devices. You have to remove them before backing and they tend to bend.
I think your Ridgeline comes with 4WD? My Pilot was and I too had to pay Honda to install he 7 pin connector. If you plan much mountain driving You'll need a transmission oil cooler. It was included in my 4WD package, but may be standard on the Ridgeline. Transmission heating is the biggest problem when hauling weight up hill. You might also want ScanGauge to monitor transmission temperature and other neat things. Simple, inexpensive, and plugs in to the OBD2 connector. You might guess that I'm an engineer (EE) too and love gauges and numbers.
A new camper is always an adventure. Just get ready to start making mods. That's the best part, aside from actually camping in it. Thumbs Up
Posted By: CharlieM
Date Posted: 02 Jun 2015 at 8:41pm
Darn, Doug. We have to coordinate our act. If folks get the same recommendations from both of us they may suspect collusion. And I'm going to have to speed up my typing. Seems a lot happens while I'm typing replies.
Doug, maybe you can better explain what Rdome to look for on the older Pods. John will be looking and I couldn't come up with the details. Nor could I remember the correct name of the rope like thing that goes in the track. Old age getting to me, I guess.
Date Posted: 02 Jun 2015 at 9:54pm
You may want an extra oil cooler too.  Like the Scan Gauge Charlie mentioned, I installed an AeroForce Interceptor to monitor my vitals and long climbs can cook the oil.  Keder is the word Charlie is looking for, the older pods had a smaller C channel so need a smaller keder, which is what feeds into the C channel.
Charlie - we can conference call tomorrow to get our stories straight!
Posted By: JohnBG
Date Posted: 03 Jun 2015 at 8:16am
Originally posted by CharlieM
John,
I'm not sure what kind of WDH the seller has, but I will take a look at it.  I don't know anything about them but this helps.  What should I look for with this hitch, in my research I see several different kinds.
I found the Honda 7-pin harness online for ~$150.  I had the truck at the dealer yesterday for an oil change and stopped at the parts counter and it is almost $200 from them, plus another ~$150 for them to install it, so I may try installing it myself.  It doesn't look too hard to install.  I have to get down under the dash to install the brake controller anyway.
Yup, the Ridgeline is 4WD and comes standard with a transmission oil cooler.  Before I go up in the mountains, I may have to check out the temperature gauge.  For starters, we plan to make a few trips in flatland Florida just to get the hang of it before venturing out further.
Date Posted: 03 Jun 2015 at 10:45am
Find out what brand & type the WDH is and we can help figure that out.
Do you mean the 7-pin Bargeman connection at the rear of the vehicle, or the 4 pin wiring harness used to connect a brake controller under the dash?  The Bargeman is a generic part which can be purchased very cheaply http://www.etrailer.com/Wiring/Pollak/PK12-707E.html - like this .  A good brake controller (Prodigy) with specific harness for the Ridgeline is about $150 on the same site, maybe that is what you meant?  Installing either item is fairly easy, they just take a little time.
Keep in mind the temperature gauge on the dash may not show EITHER the actual oil or coolant temperature even though the manual may lead you to believe that.  After installing the Interceptor I found that to be true with the temperature gauge in the Chevys - the temp on the dash isn't the temperatures the computer reads and uses in its computations/warnings.  That's one benefit of using the aftermarket readers that talk to the computer.
Posted By: CharlieM
Date Posted: 03 Jun 2015 at 10:50am
John,
There are several type of WDHs available. Those that connect the spring bars to the trailer frame with short vertical chains are most common. The amount of weight redistribution is controlled by the number of links in the vertical  chain (length of the chain). These provide WDH only and no sway control. Here's an example:
http://www.etrailer.com/Weight-Distribution/Pro-Series/PS49583.html - http://www.etrailer.com/Weight-Distribution/Pro-Series/PS49583.html
Sway control can be added with a friction device that connects between a second ball on the TV and the trailer frame. These sway devices must be disconnected when you back up and are susceptible to damage if you don't. Here's an example:
http://www.etrailer.com/Weight-Distribution/Curt/17200.html - http://www.etrailer.com/Weight-Distribution/Curt/17200.html
These combos are made by Reese, Curt, Blue Ox, and many others. BTW, E-Trailer is an excellent source of info, help and parts. So with these hitches you can get weight distribution and sway control separately or combined. Some new owners try to start out with just the friction sway control, then realize they want WDH. By then they are sort of locked in to the combo.
The Fastway E2 and its big brother Equilizer WDHs provide both weight redistribution and sway control in one unit. The 600/6000# model is very popular with Podders.
http://www.amazon.com/Fastway-94-00-0600-Round-Weight-Distribution/dp/B0071L3H2E/ref=sr_1_1?ie=UTF8&qid=1433341313&sr=8-1&keywords=fastway+e2+6000 - http://www.amazon.com/Fastway-94-00-0600-Round-Weight-Distribution/dp/B0071L3H2E/ref=sr_1_1?ie=UTF8&qid=1433341313&sr=8-1&keywords=fastway+e2+6000
Depending on what your seller has you might want to use his for a while and stick with it, or buy something else. Your call.
On the Honda 7 pin harness, I never did understand why Honda did not include the extra harness and connector. They did with other models of the Pilot, but did not for the 4WD version. I think all the harnessing is in place from the dash/engine area to somewhere near the rear. Installation should be simple. Make sure you get the relay that disconnects the trailer battery charging line from the truck battery when the ignition is off. I'm not sure if that relay is part of the stock truck or must be added with the 7 pin kit.
In the Florida flatlands you will not have any trouble with transmission temperature. However, if you get a monitor you can get an idea of how it behaves. When you get to hills and mountains you'll see the temperature rise. My Pilot had an idiot light to indicate transmission over-temp. It never came on and I don't know what temp it is set for, but I always watched the ScanGauge. The idiot light was there to tell me I was in trouble. The ScanGauge told me I was getting in trouble. There are other monitor systems available. Techntrek mentioned one. They all require a code entry for setup. If you end up with the ScanGauge I can find the code for you. Just send me a private message (PM). The gauge will also tell you to turn of the overdrive while towing.
Happy towing
Posted By: JohnBG
Date Posted: 03 Jun 2015 at 11:06am
My base-model Ridgeline RT doesn't come standard with the 7-pin trailer connector and control box, so I ordered this kit:  http://www.handa-accessories.com/ridgeline/09harness.pdf - http://www.handa-accessories.com/ridgeline/09harness.pdf .  The fancier model RTL Ridgelines come form the factory with the 7-pin harness and receptacle.
I also ordered a Tekonsha Prodigy P3 brake controller with the wiring adapter that plugs directly into the Honda control box from eTrailer.
So hopefully between the two I will have everything I need for the lights and brakes.
The Ridgelines come standard with a transmission cooler, but no temp gauge, just an "idiot light" on the dash to indicate overheat.  I'll have to look into the Interceptor unit you mentioned.
I have no idea what model WDH the seller has.  I will call them and try to find out and let you know.
Date Posted: 03 Jun 2015 at 1:06pm
We both posted at the same time, Charlie, people are going to think we are the same person.
Ok, so Honda has a specialty connector at the rear of the vehicle, I see now.  That means all of the wiring is there.  If you want to save some money you could map out which pins go to which pins on the Bargeman, get the part numbers off of the relays, then return the kit.  Buy the $5 Bargeman and hook up the wires manually using the pinouts you copied.  Get the relays from a local auto parts store.
Compared to the ScanGuage and other options the Interceptor is pricey.  What I liked about it is you don't need to mess with setup codes.  You buy one specific to your vehicle brand.
Posted By: CharlieM
Date Posted: 03 Jun 2015 at 2:17pm
You really think this much knowledge, experience, and general BS could be collected in one person, Doug? They'd never believe it. Tongue
I'm basically lazy so I'd take John's approach of buying the kit with all the parts. Installation instructions look detailed enough to make success probable. At least they're not written in Chinglish.
I looked at the Intercepter on their site. Looks interesting, but they don't seem to support Hondas. But I want to emphasize to John that, regardless of what the companies say in their general capabilities section, you can only monitor what the vehicle computer puts out on the bus. The Honda guys have been trying hard to measure engine oil temp, but looks like it ain't there on the bus.
And Doug, your engine coolant temperature reading may actually be displaying the surface temperature of newly discovered Asteroid Hillary as it enters the Earth's atmosphere. Just a guess.
Posted By: Pod4Two
Date Posted: 03 Jun 2015 at 6:31pm
Welcome
Ina & Philip Kennedy
2011 -177
2014 GMC Z71 4x4
Posted By: Podster
Date Posted: 22 Aug 2015 at 9:10am
It was a while ago, but when I started considering trans temp someone here on the forum suggested a OBD II scan gauge and whoever it was, (searched but cannot find) I just want to say THANK YOU! I was totally clueless about such devices. I'm aware of the diagnostics port of course, but had no idea you could use an after market interface to tap all of the data the ecm holds and use it to monitor TV systems. So, after considering many other options I purchased the scan gauge II and it WORKS! Apparently the Ranger has a Trans Temp senor used to activate a solenoid after reaching temp to allow fluid to flow through the cooler and the scan gauge picks up the temp through the X-Gauge feature...solves so many problems trying to add an after market trans gauge, not to mention all of the whistles and bells that come with it. Thanks again! This forum rocks! Thumbs Up
Cliff & Raelynn
Ranger 4.0/178
Date Posted: 23 Aug 2015 at 8:48pm
Glad you got it working.  It is odd that the manufacturers just don't put all that info on the dash, even if only on the digital readout.
