Anode Rod |
Post Reply | Page 12> |
gpod
Newbie Joined: 23 May 2013 Location: Golden, CO Online Status: Offline Posts: 24 |
Topic: Anode Rod Posted: 26 Oct 2013 at 5:48pm |
How do I know if I need a new Anode Rod?
Matt
kymooses
Posted: 26 Oct 2013 at 6:20pm |
Anything short of that picture and you're still good to go really. Mine is going on it's 4th year next year and looks a million times better than the bad one in this pic! |
gpod
Posted: 26 Oct 2013 at 8:42pm |
Thanks! What if it looks halfway between the two, but is pink because I started to winterize it and didn't realize that you're not supposed to put antifreeze in the hot water heater?
Matt
Outbound
Posted: 27 Oct 2013 at 8:30am |
RV Antifreeze in the water heater or on the anode is fine. No harm done.
The only reason you're not supposed to put antifreeze in the water heater is because it takes a large amount of the stuff to fill it, which costs money. Because its easy to bypass and drain the water heater, and the process forces an annual inspection on the anode, its recommended to drain.
kymooses
Posted: 27 Oct 2013 at 9:50am |
Halfway is good. As long as it's not as bad as the worst of the two in the pic you're golden. Mine looks like it will go several more seasons before I need to think of replacing it.
Tars Tarkas
Posted: 27 Oct 2013 at 6:02pm |
Mine wasn't nearly worn as badly as the one in the picture but I bought a new one and put it in, and I'm keeping the old one as my spare. I guess I figure I might drain the hot water heater sometime and find the anode is totally wasted and want to use the spare to get by for a until it's convenient to pick up another one.
TT |
FJ Cruiser |
gpod
Posted: 27 Oct 2013 at 6:36pm |
Thanks for all your tips. This is my first time winterizing. Do people usually leave the anode out over the winter? This would let the tank to dry out and not leave a little water in the bottom to get funky...? What is recommended?
Matt
kymooses
Posted: 27 Oct 2013 at 8:00pm |
I stick mine back in the hole so I don't lose it over the winter. Cause if it goes somewhere other than in that compartment I'd end up having to buy a new one each season. I just don't screw it in. So it's open to dry out completely.
My thoughts on that little bit of leftover water, by springtime what didn't evaporate out or freeze off will be flushed out with lots of clean water when I dewinterize.
gpod
Posted: 27 Oct 2013 at 9:50pm |
Good idea. Thanks!
PS. If you are the owner of "MoosePod", Thank You! Awesome u-tube video on winterizing. I followed your directions step by step and it went smoothly.
Matt
Posted: 27 Oct 2013 at 10:05pm |
I recommend putting it back in to prevent rust on the threads.
