  New Posts New Posts RSS Feed: Trickle charge 2 12 volt batteris in series.
Topic ClosedTrickle charge 2 12 volt batteris in series.
Jdub View Drop Down
Direct Link To This Post Topic: Trickle charge 2 12 volt batteris in series.
    Posted: 13 Oct 2013 at 6:54pm
I have read two seeming contrary set of directions.
The batteris are out of the pod and in the garage, both fairly charged. My plan was to hook them in tandem, black to black, red to red, just like they came off the pod.
But how do I put on the charger? Do I first put the red on one of the batteries, and black on the second battery, or both red and black on the same battery?  And then plug in the charger.....
I have read ABSOLUTE opinions either way so I am confused.
Winterizing the pod, is BTW, pretty simple.  Antifreeze is cheap.
Putting the cover on was the biggest challenge.....that is a once a year job.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 13 Oct 2013 at 7:35pm
While when the positive poles are cabled together any point in the circuit is electrically the same I would put the positive from the charger to one battery and the negative from the charger to the negative on the other battery.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 13 Oct 2013 at 8:48pm
Yup, that helps to prevent possible problems.
