  New Posts New Posts RSS Feed: which r-pod should I buy?
Topic Closedwhich r-pod should I buy?
 Post Reply Post Reply Page  <1 23456 14>
sammycamper View Drop Down
Direct Link To This Post Topic: which r-pod should I buy?
    Posted: 27 Sep 2013 at 12:24am
Thanks, Bob; and thanks to Marwayne for identifying the switch for me by private message.
2012 rPod 173
2008 Trailblazer 4WD V6
Sleepless View Drop Down
Direct Link To This Post Posted: 26 Sep 2013 at 11:35pm
Originally posted by sammycamper
Originally posted by furpod
3) the water heater is DSI, and also 120v electric. So no pilots to light, and in fact when camping with full hookups, no propane needed (for hot water).
We have a 2012 RP-173, and I'm sure our hot water heater is LP only. If it's supposed to work on electricity when hooked up, it doesn't.
No, it is also 120 volts.  Unless the water heater element is burned out, there are 2 basic reasons why it is not working when hooked up.  First, make sure the circuit breaker for the hot water heater is in the "On" position.  Second, make sure the electrical switch on the heater itself is turned on.  Do a forum search and you will find a few posts and photos showing the exact location of the switch on the heater.
I keep the switch on the heater turned on all the time.  If I want it to operate on LP only, I just flip the breaker off.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 26 Sep 2013 at 11:11pm
2012 rPod 173
dsmiths View Drop Down
Direct Link To This Post Posted: 26 Sep 2013 at 8:22pm
I do the same as techntrek. I have a cheap short 6inch level I keep in the storage area. I set it on the counter top before unhitching to get it level left to right. I then put it on the floor in the door way after the wheels are chocked and get it level front to back. Donna watches the level as I crank the tongue jack. After all is level then the stabilizers go down, power cable plugged in, hot water heater switched to electric, scan t.v. your good to go.
Dane and Donna Smith
2011 RP-172
lift kit
Direct Link To This Post Posted: 26 Sep 2013 at 2:53pm
There's an app for that.
XClinometer.
It's free.
Direct Link To This Post Posted: 26 Sep 2013 at 2:47pm
 I use a short level, probably 8 inches long.  I put it on the floor inside the door to get it level side-to-side, then I put it on the tongue while doing the front-to-back leveling.
SchipperPod View Drop Down
Direct Link To This Post Posted: 26 Sep 2013 at 2:19pm
Can we talk about leveling? I bought those small, stick-on levels, but would just a basic carpenter's level be better? would you place it on the floor in front of the kitchen area or on the kitchen counter?
Happy tails and trails!
Teri & Jeff Black
Plus 4 Schipperkes: Kodi, Jessie, Maggie & Bear
2014 R-Pod 178
2013 Santa Fe Sport Turbo
Direct Link To This Post Posted: 24 Sep 2013 at 8:56pm
Also, check your stabilizers on longer trips, vibrations can cause them to extend during travel causing contact with the ground, you don't want that. I am going to make simple clip pin safetys to keep mine from coming down during travel.
2011 RP-172
lift kit
CharlieM View Drop Down
Direct Link To This Post Posted: 24 Sep 2013 at 10:17am
All correct. I didn't mean to imply forced or jacking operation. Just that my old 12V drill sometimes got tired, especially as its battery ran down. And, it is good to make sure the jacks are tightly retracted to maximize gas station ground clearance.
Direct Link To This Post Posted: 24 Sep 2013 at 8:59am
You don't want "forceful operation" of the stabilizers. You want ground contact and one turn. More than that can twist the chassis and prevent proper operation of the door and slide.
This is absolutely correct.  These are stabilizers, not jacks, and little force is needed to lower them.  Use a regular driver drill to lower the stabilizers.  It goes without saying, use a cordless drill especailly if conditions are damp.
Bob
