  New Posts New Posts RSS Feed: CB RADIO
Topic ClosedCB RADIO
loampey View Drop Down
Direct Link To This Post Topic: CB RADIO
    Posted: 05 Sep 2013 at 3:50pm
Has anyone installed a cb in their pod. Looking for Ideas on antenna location. I'm thinking about using the rear hitch as a possible location. Any thoughts or ideas welcome. Bill
Seanl View Drop Down
Direct Link To This Post Posted: 05 Sep 2013 at 7:07pm
ground plane is going to be an issue wherever you install it. You are going to have to install an antenna with the ground plane built into the antenna elements. You could probably mount it on the rear hitch or on the TV antenna Mount.
TerryM View Drop Down
Direct Link To This Post Posted: 05 Sep 2013 at 8:54pm
I put a steel whip on the spare tire mount and it worked great.  The SWR was fine also.
Terry
Direct Link To This Post Posted: 05 Sep 2013 at 9:27pm
In reading up on mounts for amateur radios, receivers/hitches are mentioned as a bad choice because it throws a lot of the radiated energy into the ground.  Can't beat it as a secure mount and w/o any modification necessary to the vehicle, though.
