surfsup
Topic: hey Posted: 12 Aug 2013 at 4:57pm |
Originally posted by CharlieM
Originally posted by surfsup
yea, I figured to have the "tow" selector on most of the time - which would keep it in 4th gear a lot. but 4th gear is plenty tall enough for 60 mph, so no concerns there. have you run the team through the smokey mountains yet? | One small point: Unless the Ridgeline has a different 5-speed transmission than the Pilot, both 4th and 5th gears are overdrive. The "towing" gear, D3, is about 1:1. You cannot lock the transmission in 4th, but you can lock out the overdrives by using D3. |
I had to go look, you're correct. So it looks like I have a D3 passing trigger on the hand grip and a D3 gear "recommend tow" shift position (which I assumed was a D4 selector) on the console... book says only use D on level roads.
'12 Honda Pilot 4x4 (Touring)
GA_RPOD_178
Posted: 12 Aug 2013 at 4:41pm |
You are correct Charlie. I have not had to lock in D3. I find the rev's much too high. It has kicked down there at times, but we are usually in D4.
[/URL]
CharlieM
Posted: 12 Aug 2013 at 4:10pm |
surfsup
Posted: 11 Aug 2013 at 11:15pm |
ok thx, I'm reading up on the E2 WDH... I'll move any further discussion on towing elsewhere. appreciate the welcome and info!
GA_RPOD_178
Posted: 11 Aug 2013 at 11:07pm |
Not yet.
[/URL]
surfsup
Posted: 11 Aug 2013 at 10:44pm |
GA_RPOD_178
Posted: 11 Aug 2013 at 10:35pm |
Originally posted by GA_RPOD_178
Welcome! Lot's of knowledgeable people here. (I'm not one of them). |
oh contraire Georgia, your tow vehicle has the same Honda innards as mine... so I'm positive your knowledge of how the pair is working for you will be very valuable information!
... so from your experience, how's the Ridgeline and the 178 together?
Much better after adding E2 WDH. It gets me there, but mostly in 4th gear, about 12 mpg.
[/URL]
surfsup
Posted: 11 Aug 2013 at 10:28pm |
GA_RPOD_178
Posted: 11 Aug 2013 at 10:08pm |
[/URL]
rex
Posted: 11 Aug 2013 at 6:27pm |
Welcome to the world of podding!!!rex pHp stuart fla
jrr
