Where do you hang the TP |
francoisfrogpod
Senior Member Joined: 24 Feb 2013 Location: Missouri Online Status: Offline Posts: 109 |
Topic: Where do you hang the TP Posted: 05 Aug 2013 at 6:45pm |
I use the same thing you describe, 21Grandma. Works great.
Denny and Linda
2013 Pod 177 '08 Santa Fe |
21grandma
Groupie Joined: 04 Jun 2013 Location: Dubuque, Iowa Online Status: Offline Posts: 83 |
Posted: 05 Aug 2013 at 2:33pm |
I did the same thing, padded it with some leftover non-skid shelf liner. Works great. Very cheap |
21grandma
Kokopod
Senior Member Joined: 26 Feb 2013 Location: Southwest WY Online Status: Offline Posts: 113 |
Posted: 05 Aug 2013 at 11:35am |
Walmart has a great TP holder that hangs on the edge of the sink by a U-shaped hook - very simple, very cheap. Easy to take off before showering (oops - I forgot and a roll of TP doesn't dry out well!). Found it in the bathroom supplies area. One thing we did, however, was put pads on the inside of the hanger - it slides a bit in transit and marks up the edge of the sink.
2017 Jayco Melbourne 24k
2013 Premier 19FBPR Formerly-2013 R-pod 177HRE 2011 Dodge Durango Love a good road trip |
Outbound
Posted: 05 Aug 2013 at 10:48am |
I bought a plastic, surface-mount toilet paper roll holder from WalMart and mounted it (with 3M tape) fairly high on the wall behind the toilet - basically when sitting on the toilet, its just above my left shoulder. In my 171, its the most protected corner when the shower curtain is closed. In four years of pod ownership, I've never had a problem with TP getting wet.
asreichler
Newbie Joined: 30 Jul 2013 Location: austin tx Online Status: Offline Posts: 35 |
Posted: 04 Aug 2013 at 11:29pm |
Krogpod where did you get it?
Allen
2014 178 TV 2004 Dodge 2500 deisel
KrogPod
Newbie Joined: 07 Jul 2013 Location: Central TX Online Status: Offline Posts: 26 |
Posted: 04 Aug 2013 at 11:03pm |
Simple but works
Paul |
2014 RP-172, AKA KrogPod
2003 S10 ExCab V6 4.3L Automatic Central Texas |
Posted: 04 Aug 2013 at 10:37pm |
As in how to keep it in the bathroom? I went with simple but effective. Took about a foot of 12 gauge copper wire (with white insulator, not bare wire), and just bent either end so it hooks over the hot/cold valves in the bathroom. Roll goes on the middle, then we take a plastic shopping bag and that hangs on either side of the roll for trash. When we use the shower the whole thing gets moved out of the bathroom.
asreichler
Posted: 04 Aug 2013 at 9:11pm |
What are the ways you deal with the roll of TP. I did a search but,pun intended, I came up dry.
Tks Allen
