Where do you hang the TP
URL: http://www.rpod-owners.com/forum_posts.asp?TID=3803
Printed Date: 18 Aug 2025 at 6:03am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Where do you hang the TP
Posted By: asreichler
Subject: Where do you hang the TP
Date Posted: 04 Aug 2013 at 9:11pm
What are the ways you deal with the roll of TP. I did a search but,pun intended, I came up dry. Tks Allen
------------- 2014 178 TV 2004 Dodge 2500 deisel
Posted By: techntrek
Date Posted: 04 Aug 2013 at 10:37pm
As in how to keep it in the bathroom? I went with simple but effective. Took about a foot of 12 gauge copper wire (with white insulator, not bare wire), and just bent either end so it hooks over the hot/cold valves in the bathroom. Roll goes on the middle, then we take a plastic shopping bag and that hangs on either side of the roll for trash. When we use the shower the whole thing gets moved out of the bathroom.
Posted By: KrogPod
Date Posted: 04 Aug 2013 at 11:03pm
Simple but works
Paul
------------- 2014 RP-172, AKA KrogPod
2003 S10 ExCab V6 4.3L Automatic
Central Texas
Date Posted: 04 Aug 2013 at 11:29pm
Krogpod where did you get it? Allen
Posted By: Outbound
Date Posted: 05 Aug 2013 at 10:48am
I bought a plastic, surface-mount toilet paper roll holder from WalMart and mounted it (with 3M tape) fairly high on the wall behind the toilet - basically when sitting on the toilet, its just above my left shoulder. In my 171, its the most protected corner when the shower curtain is closed. In four years of pod ownership, I've never had a problem with TP getting wet.
------------- Craig :: 2009 RP171 towed by a 2017 F150
Posted By: Kokopod
Date Posted: 05 Aug 2013 at 11:35am
Walmart has a great TP holder that hangs on the edge of the sink by a U-shaped hook - very simple, very cheap. Easy to take off before showering (oops - I forgot and a roll of TP doesn't dry out well!). Found it in the bathroom supplies area. One thing we did, however, was put pads on the inside of the hanger - it slides a bit in transit and marks up the edge of the sink.
------------- 2017 Jayco Melbourne 24k
2013 Premier 19FBPR
Formerly-2013 R-pod 177HRE
2011 Dodge Durango
Love a good road trip
Posted By: 21grandma
Date Posted: 05 Aug 2013 at 2:33pm
Originally posted by Kokopod
Walmart has a great TP holder that hangs on the edge of the sink by a U-shaped hook - very simple, very cheap. Easy to take off before showering (oops - I forgot and a roll of TP doesn't dry out well!). Found it in the bathroom supplies area. One thing we did, however, was put pads on the inside of the hanger - it slides a bit in transit and marks up the edge of the sink. |
I did the same thing, padded it with some leftover non-skid shelf liner. Works great. Very cheap
------------- 21grandma
Posted By: francoisfrogpod
Date Posted: 05 Aug 2013 at 6:45pm
I use the same thing you describe, 21Grandma. Works great.
------------- Denny and Linda
2013 Pod 177
'08 Santa Fe
