  New Posts New Posts RSS Feed: Charge on 115v
Topic ClosedCharge on 115v - Event Date: 01 Aug 2013 - 30 Aug 2013
Lefty View Drop Down
Direct Link To This Post Calendar Event: Charge on 115v
    Posted: 01 Aug 2013 at 1:23pm
Newbie question. I will be storing pod in enclosed shelter that has 110/115v outlet. Will the batteriy charge during storage if the Pod is plugged into the outlet during down time when we're not using it? The outlet is a typical three prong houses plug.
Direct Link To This Post Posted: 01 Aug 2013 at 1:29pm
The pods have a good 3-stage charger (in the converter) which will maintain your battery if left plugged in.  You still should check the water in the battery regularly until you are sure it isn't being boiled away from over-charge.  It shouldn't happen with these chargers but it could.
The alternative is to disconnect the battery from the pod when the pod isn't plugged in.  If you don't the LPG detector will drain it and then kill it within 2-3 weeks.  Then make sure you reconnect the battery and plug the pod in overnight at least once per month.  During the winter months you can go 2-3 months between top-off if it is cold where the pod is stored.
Direct Link To This Post Posted: 01 Aug 2013 at 6:12pm
Thank you. So, I don't need a battery tender do I?
Direct Link To This Post Posted: 01 Aug 2013 at 6:41pm
Nope, you have one built in. Just use the hockey puck converter to hook your 30 amp to the 15 amp plug. As long as you don't run the A/C you will be fine.
Direct Link To This Post Posted: 01 Aug 2013 at 6:47pm
Thanks
Direct Link To This Post Posted: 01 Aug 2013 at 9:35pm
Even with the A/C you will be fine, it only uses about 1000 watts while the compressor is running.  Add a few hundred more for the converter and you are still below 15 amps.
P&M View Drop Down
Direct Link To This Post Posted: 02 Aug 2013 at 8:44am
Unless you have run an extension cord from the garage to it so you can have the A/C running while working inside of it on a hot day and you maybe forgot that your 2 freezers in the garage are on the same circuit and when they kick in at the same time the A/C is running the breakers on the house electrical panel keep tripping off.
Or so I've heard ... Embarrassed
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Direct Link To This Post Posted: 02 Aug 2013 at 6:23pm
So a birdie told you?
