How critical is "tow ball height"? |
Post Reply | Page <123> |
Topic: How critical is "tow ball height"? Posted: 20 May 2013 at 9:44pm |
Take a look at this, see if there is anything you are overlooking: http://www.rpod-owners.com/forum_posts.asp?TID=1723&PID=29812&title=creating-an-instruction-maintanence-manual#29812
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 20 May 2013 at 7:28pm |
I filled the water tank today and took the pod for a test run, and I'm getting a little sway. I have the nose down and it drops the truck just at 2" . Guess for traveling I'll just put 5 or 10 gal in it? Moe
Kickstart
Senior Member Joined: 20 Sep 2010 Location: Ocean Shores, W Online Status: Offline Posts: 267 |
Posted: 18 May 2013 at 12:29pm |
No, not necessarily, but if your trailer is nose up some, and/or your tow rig is marginal, then this will really lighten up your hitch weight with the added weight behind the trailer axle. In my case, I had just traded trailers, was nose up, hadn't dialed in my WDH yet, and had a partially full water tank behind the trailer axle. The state patrolman who handled the wreck was a trailer guy, quizzed me, and said it was a "Perfect Storm" type deal with several things factoring in--inadequate WDH set up, low hitch weight due to added weight behind the axle, water slosh in that tank, short wheelbase truck (even though a fullsized P/U), AND the wind gust was so instant and severe that control was immediately lost. I had my choice of a 200' drop on the left and a rock wall on the right. I wheeled it over and chose the wall. No injuries. So a Prodigy, WDH, and sway control weren't enough to overcome Mother Nature and my ineptitude .
You're from Washington State, so you may be familiar with the winds in the Columbia River Gorge.
'12 Toyota Tundra '05 Sportster (half a Harley) Retired-We're on Beach Time! |
Craneman
Posted: 18 May 2013 at 10:25am |
Kickstart,
Help me get this straight, are you saying when towing down the highway , the water tank should be empty?? We haven't towed ours other than to bring it home. Moe
Seanl
Senior Member Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
Posted: 17 May 2013 at 10:35pm |
Once you get the trailer hooked up you will probably find that it is nose down. I have more than an inch of sag in my tv even with the WDH on.
Kickstart
Posted: 17 May 2013 at 6:59pm |
At some point nose up will really put you on the edge of sway. If your Pod, like my 175 has the fresh water tank behind the axle, then do not run with the tank with water in it, and pack lightly behind the axle. Any additional weight behind the axle will lighten your hitch weight, and the slosh from a partially full water tank will add to the propensity to sway. Do you want a marginal set up to put you close to the edge? I didn't follow the rules once, and it cost me--light hitch weight, partially full water tank behind the axle, and hungus wind gust. WDH, manual brake control and anti sway couldn't overcome my inattention to the rules. I thought that close was good enough. I don't want to be harsh, but I also don't want others lose their tow rig and trailer like I did (20' Layton and F150 with 7000 miles). Damn, that was a beautiful truck! Do what you want, but beware, and please don't tow in front of me nose high.
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Posted: 17 May 2013 at 6:27pm |
The refrigerator only needs to be horizontal when the Pod is at rest. Towing rocks the evaporative system enough so that the frig runs without a problem. (If you adjust the Pod to be horizontal while towing...the refrigerant is constantly being sloshed around anyway). So the best advice is a slight downward tilt to the front to help with sway control.
TIDALWAVE
coopercdrkey
podders Helping podders - pHp Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
Posted: 17 May 2013 at 4:48pm |
I have not actually hooked up to the new TV- I will do so Sunday night in preparation for our little outing.
I have those level vials which were installed quite carefully, and I will have a much better idea of what's going on after parking on a level surface. Once in camp, we always disconnect and level anyway. I did back in close enough to the 'Pod to connect the 7-pin. Everything was perfect.
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
Posted: 17 May 2013 at 2:10pm |
Nose-down or level is recommended primarily to prevent sway. Nose-up induces sway. My popup was a sway death trap and I had to keep it very nose-down to help. That said, I have no choice with my Suburban. I bought the longest shank they had for the E2 and I'm still slightly nose-up. I do have the risers. When it is time for new tires in the next year or two I'll look into tires with a larger outer circumference to try to gain a little more height. |
CharlieM
Posted: 17 May 2013 at 1:19pm |
The quick answer is "no problem". The most critical item is the refrigerator, which should be level (trailer front-to-back) to within about 3 degrees. I don't have a 177 here, but the pictures look like the wheels are about 13 feet from the ball. If so, the ball can vary by about +/- 8 inches and still be OK if the camper is parked. If you're in motion it doesn't make any difference.
The only other consideration is that it is somewhat preferable to tow slightly nose down or with the ball slightly lower than level. This is to protect the rear leveler jacks which are vulnerable to hitting the ground on dips, speed bumps, and curbs. Onwards and outwards to the camp grounds, |
