Picture help |
TerryM
Topic: Picture help Posted: 25 Aug 2012 at 3:29pm |
Does anyone have a program that would allow you to make some changes to this picture?
If so I can explain what I want done. Terry |
Seanl
Senior Member Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
Posted: 25 Aug 2012 at 4:56pm |
I could but it would depend on what you wanted done whether I had the skill to do it.
TerryM
Posted: 26 Aug 2012 at 1:36pm |
The biggest thing is removing the background.
Terry |
Posted: 26 Aug 2012 at 6:18pm |
Do you want the black changed to white on the background?
TerryM
Posted: 27 Aug 2012 at 7:59am |
No, I don't want any background. The reason is this; I plan on giving a copy of it to a locale company so they can make a plastic stick-on for the door of my F-150. I'm sure they can do it but the charge would kill me!
I talked to a place about doing it with paint but they wanted $800.00 to do it! Terry |
FuzzySproket
Newbie Joined: 28 Jun 2010 Location: CT Online Status: Offline Posts: 9 |
Posted: 27 Aug 2012 at 8:22pm |
If all you want to do is remove the black you can open it with MS paint.
Change color1 to white, select the eraser, set the size. use the slide to change the view (bottom right) It will take a little time but it's your time, save often and most of all there is an undo button (top right) just in case. hope that helps,surely not the only or fastest way. |
Tom & Cindy
2010 174 RPod 2013 Ford F250 |
Posted: 28 Aug 2012 at 2:16pm |
I can change the black to non-black pretty easy in Photoshop, but I'm not sure about making it transparent - which is what I believe is needed here. |
bhamster
Senior Member Joined: 19 May 2011 Location: Washington Online Status: Offline Posts: 165 |
Posted: 28 Aug 2012 at 3:48pm |
How about this:
the background is transparent although your browser may show it as white
Posted: 28 Aug 2012 at 9:40pm |
That looks like winner to me.
TerryM
Posted: 31 Aug 2012 at 4:10am |
That last one looks pretty good. Thanks!
Terrry |
