Taking down the mini blinds? |
Post Reply | Page 12> |
Hodge-PODge
Senior Member Joined: 11 Apr 2011 Location: Calhoun, GA Online Status: Offline Posts: 539 |
Topic: Taking down the mini blinds? Posted: 24 Jun 2012 at 9:00pm |
Can anyone tell me HOW to take down the mini-blinds?
THANKS! Diane
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350 "A man travels the world over in search of what he needs, and returns home to find it." |
The E Train
Groupie Joined: 09 Jun 2012 Location: Western, NY Online Status: Offline Posts: 88 |
Posted: 24 Jun 2012 at 9:23pm |
I had to fix a valance on my 176T, so if your's are similar I might be able to help. There are 2 small levers that need to be opened to the right. Sneak a finger up between the front of the blinds and the valance, at the very top, and slide it along from one end. About 1/3 of the way across, you should feel a small (very small) protrusion; that is the lever. Slide the lever to the right (same for the one near the other end). then slide the whole unit towards you just a little. the unit should be free of the bracket. If you can't get it, let me know and I'll take / post pictures.... It is like everything else... Impossible, until you know how to do it, then it is trivial.Good Luck.
2002 Dakota (pulling a) 2012 R-Pod 176T |
Hodge-PODge
Posted: 09 Jul 2012 at 1:32am |
Thanks E Train. I just got back from my son's wedding in Florida. I'm anxious to try your suggestion to see if it works. I would expect that the blinds are the same in all the R-Pods. I would just leave the bracket if it wasn't such a tight squeeze between the blinds and the small curtain rod.
Posted: 09 Jul 2012 at 9:40am |
It is easy to remove everything. I had the entire header removed for a while until I installed curtains. |
Hodge-PODge
Posted: 09 Jul 2012 at 8:16pm |
Tech, how did you remove the header? It seems well attached to the wall to me. I did find (feel) the lever about 1/3 the way across as E Train described. I can't get it to budge though. Maybe I should put more oomph behind it!
Diane
Podsible Dream
podders Helping podders - pHp Joined: 03 Dec 2010 Location: Hightstown, NJ Online Status: Offline Posts: 571 |
Posted: 09 Jul 2012 at 9:56pm |
Hodge, there are angle brackets at each end of the valence, two screws each as I recall. They are at a bit of an angle, but with a 2-3 inch bit in the driver, they came out easily. The little screws are less than 1/2 inch. Then there are the brackets that anchor the blinds with the little levers. They are fixed to the window frame with screws too. Remove them. I then replaced the valences with the same brackets and screws. Then we used spring loaded rods to support the curtains.
Chris and Walt
'10 RP-171 'Free Spirit' '13 Dodge Durango Crew 5.7 L Hemi V8 |
Posted: 09 Jul 2012 at 10:12pm |
What he said ^^^
Podsible Dream
Posted: 09 Jul 2012 at 10:19pm |
Sorry to steal your thunder!
Chris and Walt
Posted: 10 Jul 2012 at 7:11am |
Oh no, you answered better than I would have. Glad you did. I would have said something closer to "ugh, brackets on wall, turn screws, fall off wall". |
The E Train
Posted: 10 Jul 2012 at 1:29pm |
And I'll add that those levers may require the additional oomph. Both of mine came off easy, but went on very tight.
