TrinityTurret
Topic: I need a course in R-Pod water Heater 1001 Posted: 23 Oct 2013 at 3:42pm |
When I remove the anode rod, the water pours into grooves of the outer rim..and seeps down along the inside of the Rpod, actually seeping out the sprayed-on foam around the low point drain. Is there any way to avoid this other than my ridiculous visquine and masking tape?
There's only one way...
hogone
Posted: 23 Oct 2013 at 4:04pm |
Mine is heavily siliconed/caulked in those areas, I have not had any interior water problems from removing the anode rod. and you mentioned it is coming out by the low water point drains, that seems to be along way for it to go. i would try siliconing the area well.
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
TrinityTurret
Posted: 23 Oct 2013 at 4:07pm |
Well, I TRIED to 'silicone' it....I had a tube of 'silicone', but it was 'silicone caulk', and even after waiting around for four hours, it is still like gooey toothpaste...so I'm gonna put tape and visquine all over it just to get the heater emptied before the winterizing (antifreeze). I was hoping there was a magic solution, like "press the blue button and that will divert the water heater dumping into the gray water tank", LOL :)
hogone
Posted: 23 Oct 2013 at 4:31pm |
a blue button would be nice!!!!!!
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Posted: 23 Oct 2013 at 4:52pm |
If you want, you can just set you valves to winter/storage, and otherwise do your winterization now, and drain the WH when you get time. It is a solid 6 gallons of water, and while it freezing solid will be bad, unless you live pretty far north, it isn't going to stay below freezing, and be far enough below freezing to solidify a insulated 6 gallon container for a bit longer this year.
TrinityTurret
Posted: 23 Oct 2013 at 4:56pm |
I noticed the anode rode hole is about an inch above the bottom of the heater...thusly, there is still about a half-inch of water in the heater. Will THAT AMOUNT of water cause any problems should it freeze up? If so, without some kind of pump, I can't get all the water out...
kymooses
Posted: 23 Oct 2013 at 5:59pm |
Never has caused a problem in ours.
TrinityTurret
Posted: 23 Oct 2013 at 6:17pm |
Thanks again...we're ALMOST ready to relax, LOL...
marwayne
Posted: 23 Oct 2013 at 7:04pm |
I use a 1/8" tube cut a good angle on one end and siphon the rest of the water out. I don't want to take a chance at - 30* or worse.
Posted: 23 Oct 2013 at 7:34pm |
There have been years where I have only used the low-point drain to remove the water from the WH. No issue with damage from the remaining water. It would solve the seepage issue, too.
