  New Posts New Posts RSS Feed: Fridge Circuit
Topic ClosedFridge Circuit - Event Date: 14 Oct 2016
voisj View Drop Down
Direct Link To This Post Calendar Event: Fridge Circuit
    Posted: 25 Oct 2016 at 12:36pm
On my 180 the fridge is on the same circuit as the GFCI plug, but if i trip the test button on the GFCI the fridge still works. So it's either pigtailed to the hot side or they ran a separate wire.
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 25 Oct 2016 at 2:51pm
The fridge brains are 12v.. it won't work on 120v if it's on the GFCI circuit and that is tripped. It will still work in 12v and gas mode just fine.
Direct Link To This Post Posted: 25 Oct 2016 at 9:02pm
+1
sailor323 View Drop Down
Direct Link To This Post Posted: 26 Oct 2016 at 4:08pm
Does your fridge have its own breaker?
Direct Link To This Post Posted: 28 Oct 2016 at 12:35pm
The  main 110v panel  looks like this,
#6 on the 110v side is  marked as GFCI / Refer.
 The power runs from the main panel over, (under), to a GFCI elec plug next to the refer,( in the 180) When the breaker is turned off the refer won't run on 110v.
When i just push the button on the GFCI plug next to the refer all elec plugs in or on the unit go off, As they should,  but the refer still works on 110v meaning they either ran to the refer first or pigtailed the refer line to the hot side of the GFCI .
SLOPODMODS
John&Sue,SLO,CA
CharlieM View Drop Down
Direct Link To This Post Posted: 28 Oct 2016 at 1:13pm
That looks good. You would not want the fridge to go off if an appliance tripped the GFCI. However, what does the GP -3 breaker control?
Direct Link To This Post Posted: 28 Oct 2016 at 2:24pm
The only thing that shuts off when i turn off the #3 breaker is the power to the Television outlet
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 28 Oct 2016 at 2:34pm
Very interesting. "Let no two Pods be built the same" - Forest River.
Direct Link To This Post Posted: 28 Oct 2016 at 6:37pm
Wow!  very bad idea to have the fridge on a GFCI protected circuit.  If it were my pod, I'd either parallel off of circuit nbr 3 for the fridge or install piggy back breakers on nbr 3 or, space permitting a separate breaker for the fridge.  Don't understand FR reasoning here, it seems a no-brainer
Direct Link To This Post Posted: 28 Oct 2016 at 8:54pm
Just to be clear - if you trip the GFCI and leave the fridge in AC mode overnight, it stays cold?
That would be unusual, since the fridge's AC outlet is exposed to the outside elements, which is why it is supposed to be run through the GFCI.
