  New Posts New Posts RSS Feed: Torsion axel issue?
Topic ClosedTorsion axel issue?
ToddLat View Drop Down
Direct Link To This Post Topic: Torsion axel issue?
    Posted: 23 Jun 2014 at 7:50pm
I looked at the brackets when I was at the camper. They do not look bent and the hardware looks tight but I did not have the proper tools with me to verify. Trying to get an appt at our local rpod dealer.  Not looking good for our trip next week. Fingers crossed
I did not measure the axel so I don't have that answer. I don't think that is the issue as the axel would still absorb shock even if it were out of location or a bracket were bent.
The fact is that the left side of the axel is not absorbing shock. The tire is taking it all. I guess I will see what the service dept. says and go from there. Cry
I will let everyone know at the end what the issue is. Thanks for all of the suggestions
Todd
Todd and Beth
2013 RP 176 T
2013 Nissan Pathfinder
Old Hippy View Drop Down
Direct Link To This Post Posted: 23 Jun 2014 at 7:55pm
Do you think maybe the fender was mounted wrong !?
Direct Link To This Post Posted: 23 Jun 2014 at 8:06pm
My vote on the appearance is a fender that isn't exactly where it should be.  At least one of my wheels looks the same, and it isn't the wheel.
sammycamper View Drop Down
Direct Link To This Post Posted: 24 Jun 2014 at 1:02am
How do things look in terms of corrosion? Could one side of your suspension be fused by rust? You might want to try jacking up your camper to see how the wheels hang when they are not load bearing. Do they both hang freely and symmetrically?  I hate to see you give up on your camping plans. I'm feeling some urgency about solving this (aka, this could happen to me).
Sam
2012 rPod 173
2008 Trailblazer 4WD V6
Direct Link To This Post Posted: 24 Jun 2014 at 5:25am
I have yet to jack it up. When I looked last night there was no evidence of rust around the axel. I as well want to get to the bottom of this.  I do not want to have to cancel my plans but it is a two and a half hr tow and I am not going to do that with what is acting as a solid axel. Still trying to get a hold of service. Argh.
Todd and Beth
2013 RP 176 T
hogone View Drop Down
Direct Link To This Post Posted: 24 Jun 2014 at 6:50am
todd:  i can't help much with your problem, but I can say my fenders are not mounted equally front to back or up and down.  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Budward View Drop Down
Direct Link To This Post Posted: 24 Jun 2014 at 7:30am
I am very familiar with both Dexter and Alko torsion axles and don't see how it could lock unless it was severely overloaded somehow and jammed in the up position, or the rubber shock element completely failed.
Have you had someone go in the trailer and jump up and down to confirm the axle is not operating?
On my 179 the tires are very supple with a fair amount of movement just walking around in the trailer.
I also notice a lot of tire sidewall flex when towing, much more than I've ever seen on other trailers even though I run the full 50 psi pressure.
2014 179
Direct Link To This Post Posted: 24 Jun 2014 at 9:54am
I am going to jack it up after work tonight to see if I can find anything else (if the axel stays put or rotates back to normal).  Will also jump inside the POD to see if there is any flex.  As of now, the earliest I can get it looked at is July 30.
I have never seen the sidewalls flex as much as they did the other day (and acutally see the tire leave the road surface) and it is on the same road with the same surface that I am always on (between the house and the main road).  Normally I see the axel flexing up and down but not this time.  Maybe I am just paranoid but I am always trying to be as safe as possible when towing.  I dont like puting my family or anyone else in danger if I can help it.
Todd and Beth
2013 RP 176 T
Direct Link To This Post Posted: 24 Jun 2014 at 11:10am
     I am going to change this thread a little but the same subject. I read that a torsion axle has a shorter life span than a leaf spring axle. Does anyone know how short and what part fails?
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 24 Jun 2014 at 11:31am
I know Dexter has a 5 year warranty on their torsion axles.   I have a trailer over 10 yrs old with them and no problems yet.
My guess on failure would be the rubber torsion rods inside the axle beam.
ToddLat- if you determine you have a Dexter axle I'd give them a call-  in my experience they have superb customer service.   (574) 295-7888
You should get the lot number of the axle before calling- this is a 9 digit number on the right rear of the axle under the words Dexter Axle
2014 179
