Page 123> |
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1003 |
![]() Posted: 15 Apr 2014 at 11:14pm |
If you want more cabinet space, here is how I built our corner cabinets. Pics are worth 1000 words.
Just a cabinet? That's all you did this time?
I'm kidding! Looks good, as always. I like how you created the support on the ceiling with multiple pieces to conform to the curve. Not sure I would support the floor from below with a few screws. With the dynamic loading going down the road and a full cabinet I'd put supports in from below, even though they would be visible. Maybe if you screwed & glued on all edges that is ok.
kymooses ![]() Senior Member ![]() ![]() Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
Tech, the supports you are talking about are there, they are inside the cabinet. The strip on the ceiling is in two pieces with a cut almost through every 3 to 4", it is easier to keep it in line.
Just because you can't see them dos not mean there not there. |
Goose ![]() Senior Member ![]() Joined: 24 Sep 2010 Location: Arizona Online Status: Offline Posts: 672 |
Great job as always!!!! Goose
There is that misconception that a shelf support has to be under the shelf, not so. You can make it invisible by putting it inside the cabinet.
The supports don't have to be 2 or 3" wide, for these small cabinets 3/4" to 1" is quite sufficient. |
bmkparshall ![]() Newbie ![]() ![]() Joined: 27 Sep 2013 Location: Bear Creek PA Online Status: Offline Posts: 10 |
Looks really nice!
I'm considering a few mods, but not sure about the attachment to the wall. With wood wall supports would I need to pre-drill thru the support and wall surface and then using the pre-drilled hole in the wall surface as a guide, make the hole larger to insert a plastic wall anchor? Any help is greatly appreciated! |
B MK Parshall
2016 Silverado 5.3 V8 and R-178 Poddler |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1060 |
marwayne: you do some really nice work. hogone
Jon & Pam
This is the second cabinet in that location, I made the first one 10" deep so I wouldn't bump my head on it, as it turned out there was a lot of room left so I made the second one 14" deep and still have room to spare.
I don't use any anchors, predrill the holes in the supports so the screws go through freely and than fasten it to the wall. I use coarse thread dry wall screws (grabbers) but be careful you don't overturn them. You be surprised how well it holds. |
Beautiful work, as always.
What is your stain mix? fred
Page 123> |
