Page 123 4> |
![]() Posted: 24 Sep 2013 at 9:21pm |
These are used on the pods. Note they say even if your key code isn't on the list, if you can still remove the key in the 9 o'clock position it will be replaced. http://www.fastecindustrial.com/recall/Fastec%20Cylinder%20Recall%20letter.pdf |
Keith-N-Dar ![]() podders Helping podders - pHp ![]() ![]() Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Thanks for the information. My key number is not on the list, so I will check the locking in the morning. Things like this make this group valuable.
Keith-N-Dar
rpodcamper.com ![]() Admin Group - pHp ![]() ![]() Joined: 26 Nov 2009 Location: Reading, Pa Online Status: Offline Posts: 3990 |
And mine is one that is recalled. Will call in the morning. Thanks for the heads up.
David and Danette ![]() podders Helping podders - pHp ![]() ![]() Joined: 24 Nov 2009 Online Status: Offline Posts: 1222 |
My lock too is being recalled, has never been a problem but for safety at sometime it could be. I too will replace lock. Thank you techntrek, David
TerryM ![]() Admin Group - pHp ![]() ![]() Joined: 16 Nov 2009 Location: Saint Augustine Online Status: Offline Posts: 1950 |
I had to drill mine out. My key got stuck in it and due to trying and trying to unlock it the key broke off inside. So I just use the regular door lock.
Terry |
Sleepless ![]() Senior Member ![]() Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Thanks, Doug. I filled out the online survey and was then directed to telephone the company. It will take 7 to10 business days to receive the cylinders and keys. This is a DIY removal and replacement.
Bob |
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Thanks, Doug!
Yup - mine's on the recall list. I wonder if they'll help out a Canadian. I did have a problem with the deadbolt a couple years ago. With a lot of jiggling, I was able to get the door open; I took the lock apart and reassembled it and its been fine since. |
21grandma ![]() Groupie ![]() ![]() Joined: 04 Jun 2013 Location: Dubuque, Iowa Online Status: Offline Posts: 83 |
At least my daughters will realize I wasn't nuts when I got locked inside My-pod! We were at an overnight at one of my daughters; they were all down by the campfire. Could not get door unlocked from the inside. No one could hear me yelling. Used cell phone to call and get someone to come up and unlock door from outside to let me out. My lock is one that is listed as recalled.
21grandma
francoisfrogpod ![]() Senior Member ![]() ![]() Joined: 24 Feb 2013 Location: Missouri Online Status: Offline Posts: 109 |
Thanks, Techntrek. You saved the day.
Denny and Linda
2013 Pod 177 '08 Santa Fe |
coopercdrkey ![]() podders Helping podders - pHp ![]() ![]() Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
Fortunately, my key number was not listed, and it also passed the "9 o'clock test".
Very appreciate the heads up, though. If I leave the campsite for any reason and Joyce and the pups are inside the 'Pod, I am asked to lock the door until my return, and I would hate to think that my loved ones might be trapped inside.
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
Page 123 4> |
