Topic: Cold Weather Tip - 178 Rear Window Posted: 09 Dec 2016 at 2:21pm |
Been on a campground in AL for 6 weeks and the temp has dropped drastically for a few days. No issue with using space heater, keeps the 178 above 70 if needed. While in the rack at night noticed a drastic difference in bed area temps close to rear window. Woke me up when I rolled toward window. The rear window has only a drape for privacy. I went to Lowe's and purchased a 16" X 16' of double sided aluminum insulation that has plastic bubble material in center (about a 1/4" thick). Cut it to fit rear window and fit into deep channel around inside of window (about 14 X 46 inches). WALLAH - drastic difference in temps, at least while cold, at window. The window is tinted so the refection is minimal to outside.
Leo B
Posted: 09 Dec 2016 at 7:43pm |
Good tip!
Posted: 11 Dec 2016 at 8:48pm |
After our first year of camping in cold weather back in 2011 with our 177 we pulled the privacy curtain out and replaced it with a honeycomb, cellular shade from Blinds.com. Wow, what a difference that made. And it is nice in that we usually leave it up so we can look out of the back at the scenery, if we want privacy just pull it down and hook the ends into a pair of clips, takes only a few seconds. Not cumbersome like the factory curtain - that was a bugger to open and close. It was posted a long time ago and is somewhere in this forum's postings. If you want to see it I will search for it and repost.
Posted: 12 Dec 2016 at 8:09pm |
ditto - good tip. Popup owners use that zipped into their windows in the cold and heat. I just used tin foil on our back window but the foil bubble wrap is even better.
Posted: 13 Dec 2016 at 5:56pm |
The foil bubble wrap supplies insulation and the material fits in the window channel to look good and fit securely. Blinds are great idea, but I don't see myself sitting in bed in 178 and looking out rear window:)
Bama Pod
Posted: 14 Dec 2016 at 7:42am |
Which campground in AL? New 180 owner and compiling my list of campgrounds to visit.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
Posted: 14 Dec 2016 at 8:32pm |
I am at the MWR RV Park on Redstone Arsenal. Most folks here are somehow aligned with the military, visiting family in area, or have business in the area, or waiting on retirement and moved out of lodging where they lived in Huntsville area. It is a full service campground reasonable and well maintained. For me it is a place to live, cheaply until I retire.
