  New Posts New Posts RSS Feed: Replacement Anode Rod
Topic ClosedReplacement Anode Rod - Event Date: 23 May 2016 - 30 May 2016
Direct Link To This Post Calendar Event: Replacement Anode Rod
    Posted: 24 May 2016 at 1:15pm
I don't use hot water from the tap for drinking/cooking either. At home we have a reverse osmosis filter. Our drinking/cooking water goes through that. I use an inline water filter for the R-Pod since I don't want to install an RO filter there.
w4bgbob View Drop Down
Direct Link To This Post Posted: 24 May 2016 at 2:35pm
Thanks Stephen, i will check out Amazon and see what they have to offer.
Thanks everyone else for your thoughts, opinions, and suggestions. i appreciate the
responses, Thanks again.
Bob
A bad day hunting/camping/fishing is better than a good day at work, especially in a a 2014 Rpod 177 :)
ron/roscoe View Drop Down
Direct Link To This Post Posted: 05 Jun 2016 at 7:43pm
The cross over valve, I cannot find where they are located on my 2016 Rpod 178.  My next step is to look under the bed, have to remove the plywood there.  All I get is warm water, dealer looked at it twice, said it was ok.  Suggestions?
Ron Rowland
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 05 Jun 2016 at 8:09pm
The cross over valve should be right next to the water heater between the hot and cold lines.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Direct Link To This Post Posted: 05 Jun 2016 at 8:10pm
First, find the location of your hot water heater. On the outside, you can easily see where it is. Then look inside at that location. On the 179, it is under the queen bed in front. I don't know where it is located on the 178. There should be some sort of access panel. When you remove it, you will see the valves. The top and bottom should be open (parallel to the lines). The bypass valve should be closed (perpendicular to the line). If it is open, then hot and cold water mix and all you get is lukewarm water. During winterization, you want to close the top and bottom valves to isolate the water heater and open the bypass valve. This allows you to drain the water heater tank to keep the antifreeze from corroding the anode rod (and from wasting 6 gallons of antifreeze filling the heater). It allows antifreeze to flow through the hot as well as the cold water lines to protect them.
Sometimes, you just need to do things yourself.
CharlieM View Drop Down
Direct Link To This Post Posted: 05 Jun 2016 at 8:40pm
Yes. Find a new dealer.
Direct Link To This Post Posted: 05 Jun 2016 at 9:08pm
+1
Direct Link To This Post Posted: 05 Jun 2016 at 10:18pm
quoted for truth.
Direct Link To This Post Posted: 06 Jun 2016 at 2:59pm
Camping world is near me with a two month waiting time just to get it on their lot!
Ron Rowland
Direct Link To This Post Posted: 06 Jun 2016 at 3:14pm
I started doing some things myself since it is a significant 2+ hour drive to get to the dealer where I purchased the R-Pod. Besides, after seeing the quality of some things, I decided I could do better by doing it myself. I haven't tackled things like wheel bearings yet, but that will likely be soon. My mods list some of the things I have done.
