mtsapphire
Topic: Weak gas flow Posted: 08 Jun 2015 at 2:28pm |
New to this forum. Appreciate your help! I have a 2013 RP177. Having a problem with the gas flow (No, it's not the gas bottle!). First trip this year two days ago. Here are my symptoms: Noticed gas flame at stove cooktop was very low but enough to cook rice. Refrigerator was on gas, (level 3 of 5). Gas hot water heater went on but produced only lukewarm water, intermittently with cold water. Next morning, gas indicator light on refrigerator started to flash a warning. Turned it off. All this , I thought, pointed to need for a new gas bottle as original bottle had lasted for maybe 15-16 nights. Swapped it for a filled bottle (even though there was still some liquid swishing around in the old bottle). Now the problem is worse: stove top burners light (at very low level only) for about 2 secs. then go out. Hot water heater tries to turn on. I see a flame in the tube, but it goes out. Tries to restart. Click, click, click, Same result. Turned off the hot water switch. Swapped out the new bottle with the one for my barbecue, which I know works. Same result. Checked on-off valve at bottle. It's on. First available service appointment June 29, so I am turning to you guys! Visual inspection shows no crimps in the gas line and I have had no accidents that would have damaged the line. Do not smell gas. Is this maybe a regulator issue? Something else? Your advice much appreciated!
Posted: 08 Jun 2015 at 3:45pm |
Welcome. The immediate problem with the new tank could be the built-in high-flow cutoff valve. Make sure you turn on the valve very slowly. I count to 60. Otherwise you will trigger it and you'll have to start over or wait until it resets itself which can take a while.
Assuming that isn't the problem, your next possible issue is a bad regulator. That is the round object just after the LP tank.
A note on checking the fuel level: take a cup of hot water and pour it down the side of the tank from the top shoulder. Wait 10 seconds and then run the back of your finger down the side of the tank. The fuel line will be where it changes from hot to cold. This may not work if the tank has been sitting in the sun. Even when full it will only be 80% full, so don't think you have been ripped off.
mtsapphire
Posted: 08 Jun 2015 at 6:09pm |
Thank you, Doug. I tried the slow-turn of the gas valve as you suggested, but it made no difference. Here is a picture of my regulator setup. It looks like two very similar regulator-type objects, one facing back, one facing front. Flow is to the left. Looks like an adjustment valve with a plastic cap in the middle (above the writing) Is this whole thing the regulator? Any way to test or should I try to replace?
Mountainrev
Posted: 08 Jun 2015 at 7:03pm |
I can't help you with your problem, sorry, but the title of your post immediately made me think that my wife wishes I shared this problem personally. Sadly, I don't.
2014 177
Podster
Posted: 08 Jun 2015 at 7:40pm |
If you haven't already replaced, try this one last time. Turn all the gas appliances off, close the valve on the bottle, disconnect and wait 1 minute, re-connect and then open the valve slowly. Go inside the POD and open a stove burner and try to light it.
If that doesn't work and you are sure there is no blockage or leaks, then I would replace the regulator. They can be tested, but probably not worth the trouble.
Good luck and let us know how things work out.
Cliff & Raelynn
Ranger 4.0/178
Posted: 08 Jun 2015 at 8:23pm |
Posted: 08 Jun 2015 at 8:24pm |
I agree if it is the regulator you just need to replace it. They are fairly cheap.
mtsapphire
Posted: 08 Jun 2015 at 8:41pm |
Well, folks, I believe I figured it out. I turned the adjustment screw/valve (see photo) a 1/2 turn open. Now I have a big, fat stove flame AND warm water from the hot water heater, which is lighting and staying on. I'm assuming the fridge will now work well on gas, too. Why the valve came out of adjustment, I have no idea. If you see anything wrong with this picture, let me know. And Mountainrev, I, too, now have a strong gas flow!
Posted: 08 Jun 2015 at 8:58pm |
Sorry to jump in on this this way -- I don't have an answer, but I have a related issue.
All my gas things work fine. Heat, water heater, fridge. The stove works too, but when I have one burner on high it's like it's on low. If I light the other burner, they both burn but it's like you gotta be kidding. There's enough heat there to sense with a sophisticated scientific instrument I suppose, but not enough to cook with. I haven't looked but does anyone know if there is a valve in the supply line for the stove that might not be fully open, or otherwise kinked or blocked?
Podster
Posted: 08 Jun 2015 at 10:25pm |
Originally posted by mtsapphire
Well, folks, I believe I figured it out. I turned the adjustment screw/valve (see photo) a 1/2 turn open. Now I have a big, fat stove flame AND warm water from the hot water heater, which is lighting and staying on. I'm assuming the fridge will now work well on gas, too. Why the valve came out of adjustment, I have no idea. If you see anything wrong with this picture, let me know. And Mountainrev, I, too, now have a strong gas flow! |
Well I'm no expert, but the system is designed to withstand a specific pressure and now it may be out of adjustment. That is what the regulator does, regulates the pressure. It may have got stuck or you may have overcome the obstacle by increasing the pressure, hence the warning on the valve and the absent recommendation here to adjust it.
Of course they are your dice to roll, but I would have the system calibrated or check it yourself. It's not rocket science...you can probably find the procedure on Youtube Good luck Sir.
Cliff & Raelynn
Ranger 4.0/178
