  New Posts New Posts RSS Feed: Battery drain on R178
Topic ClosedBattery drain on R178
cody91 View Drop Down
Direct Link To This Post Topic: Battery drain on R178
    Posted: 26 Mar 2015 at 2:55pm
Has anyone figured out a quick way to prevent the parasitic drain on the battery when the keeping the Rpod in storage? I realize the microwave clock and the gas detectors are slowly drawing off the battery and perhaps pulling a fuse or disconnecting a wire would stop this. Any thoughts?
Thanks!
freezingalaskan View Drop Down
Direct Link To This Post Posted: 26 Mar 2015 at 3:40pm
Either put a kill switch by the battery (have not yet installed mine), or get a solar panel hooked up to trickle charge your battery. Or, as you say, you could probably also pull a fuse but I have not researched that.
freezingalaskan
Volvo XC90 '13
rPod 179 '16
Direct Link To This Post Posted: 26 Mar 2015 at 4:36pm
It's not the microwave clock.. It's 120v.
BUT there are several 12v parasitic loads. If you can't / don't store where you can stay plugged in, a battery cut off is the answer. Ours is a "Hella" brand.
Direct Link To This Post Posted: 26 Mar 2015 at 8:08pm
And then make sure the battery is recharged overnight every 30 days.  Reconnect the battery and plug in the pod overnight (then disconnect both again).
dsmiths View Drop Down
Direct Link To This Post Posted: 26 Mar 2015 at 8:23pm
The LP gas detector is a current hog. you can pull the 12 volt fuse for it, or take the battery out and keep it at home on a trickle charger if where you stow the pod has no 110 volt source.
Dane and Donna Smith
2011 RP-172
lift kit
