  New Posts New Posts RSS Feed: Battery maintenence and charging
Topic ClosedBattery maintenence and charging
srpntmage View Drop Down
Direct Link To This Post Topic: Battery maintenence and charging
    Posted: 17 Feb 2015 at 2:10pm
We have an rpod 179. I have installed an extra battery (interstate SRM24) for a total of 2 batteries running in conjunction. Our pod is stored at a relatives house in the country miles away from our home.
After a trip, what is the best way to recharge and maintain the batteries? Should we keep a trickle charger on constantly? Or just run the charger a few days before a trip? We are considering solar, but are not sure of what wattage and do we keep that on constantly also?
TigerPawd View Drop Down
Direct Link To This Post Posted: 17 Feb 2015 at 2:44pm
Or you could just bring the battery home, where you could keep a better eye on it.  I have done that for years when I had to store the bigger pre-Pod trailers.  Just don't tip it over or drop it in transit....
Joan, Jerry and the two Pugs
2015 R-Pod 179
Podster View Drop Down
Direct Link To This Post Posted: 17 Feb 2015 at 3:14pm
Perfect scenario for SOLAR!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 17 Feb 2015 at 10:06pm
Other than solar, either keep it plugged in, or use a trickle charger (which will use less power than the built-in converter, or the final solution.
This solution is to disconnect the battery from the pod with a battery disconnect switch or fuse, then reconnect it once every 30 days and plug the pod in overnight.  Then disconnect the pod and the battery the next day.  Also charge overnight after each trip and before each trip.
