SandD
Topic: 179 Axle Issues Posted: 18 Oct 2014 at 1:22pm |
Anyone have axle issues with rpod178 or is it only the 179?
kymooses
Posted: 19 Oct 2014 at 11:23am |
Originally posted by SandD
Anyone have axle issues with rpod178 or is it only the 179? |
It's not "an issue" with any Pod SanD. While this owner might have experienced an issue with theirs, it is not any type of known problem in the R-Pod travel trailers, on the 179's or any previous model.
Budward
Posted: 19 Oct 2014 at 4:29pm |
"Might" have experienced an issue?
2014 179
wildfire305
Posted: 19 Oct 2014 at 7:25pm |
I think all of the 2800+ pound pods toe the tires out at bottom. This gives the visual appearance that the axle is bent. It is at the capacity rating for the axle they use which doesn't leave much of a safety buffer, but isn't technically a problem. It will probably cause excessive tire wear, but I don't believe it is going to be recalled unless units start failing. I don't think we have any examples of an axle failure. Nearly all our camping is local, so I won't put enough miles on my tires to wear them out before they need to be replaced from age. This is probably what Forest River is betting on for most buyers also.
All should be more concerned about checking the lug nut torque before each trip and every 500 miles, we do have some examples of wheels falling off due to lack of proper torque. On our second trip, I got half a turn out of nearly all lugs. They were 100 pounds and tight from the dealer, so those aluminum wheels WILL loosen them.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey
2015 RP179 "73b"
OLD 2005 Viking Saga 2480ST popup
kymooses
Posted: 19 Oct 2014 at 7:36pm |
The use of that word is not meant to diminish your issue or deny it, please don't think that at all. I only mean to say that while you personally may have experienced some issue with yours, it is not true of R-Pods in general, nor the 179.
Old Dingo&Mrs.Dingo
Posted: 19 Oct 2014 at 11:57pm |
I have a "heavyweight" 'pod, I've never experienced any axle problems. When I pull it, it is always near Forest River's suggested maximum weight. I do check the lug nut torque and tire pressure before every trip.
Old Dingo and/or Mrs. Dingo
181G
2013 Jeep Grand Cherokee
David and Danette
Posted: 20 Oct 2014 at 4:10am |
The Vibes had the same 3,500 lb.axle as the r-pods and it was replaced with a 4,400 lb. axle for 2015. But the Vibe is 200 to 400 lbs. heavier than the r-pod 179. With the Vibes there was some problems with the 3,500 lb. axle in it not being able to properly handle the weight. I think if you are careful not to overload the 179 it would have no problems but it would be nice to have that extra margin of safety with a stronger axle. Perhaps in the future Forest River will replace the axle on the heavier r-pods with one stronger as they did with the 2015 Vibes.
2014 Ram 1500 Quad cab
krkees
Posted: 06 Nov 2014 at 10:47am |
Hey guys, just seeing this forum. So I have a 2013 RPOD 176. I noticed after no more than 2000 miles, that I had bad tread wear on the outside of the tire, opposite of slide out. My RV dealer took measurements provided by Dexter, and the wheel was forward about a .5 centimeter I think it was. They are testing it this week and will have more details to see if they are covering this under warranty. Needless to say, I was unable to take my camper LAST MINUTE to Colorado for the 6 weeks I was there. So I was furious, after putting on new tires for the trip and finding this. And no, I have never carried a full tank of water anywhere. I filled up and took it down the road one time, which was a 2-3 mile trip down the road at 30mph. Definitely no habit. The way it was bent or out of alignment, I would have to be hauling butt backwards and hit something to make it bend forward. I am positive it is 'defective' because I have never hit anything, never had it off road, etc. I was looking at selling it and getting the 179, and now I'm afraid to get one because of all the axel issues!
krkees
Posted: 06 Nov 2014 at 10:48am |
Oh and yes $600 for a new axle, $150 for new tire and mount, $125 shipping my axle for testing back to Dexter, $150 to install the new axle. Yep, I'm PO'd!!! AND didn't get to take it to Colorado. Thanks Dexter for selling crap!
Posted: 06 Nov 2014 at 7:43pm |
Welcome. Personally I would have taken it with me to CO with the original tires and taken care of fixing it when I got back. The tire was already damaged so nothing worse would have happened to it for one trip, and the axle wouldn't have been unsafe. Would I have taken it on a 5000 mile trip, no.
I hope those costs are being covered by FR.
