Budward
Topic: Refrigerator Temp Posted: 03 Aug 2014 at 2:17pm |
My 8501 so far is doing well, no problem maintaining in the 30's in 95+ heat. This is on propane, or AC, never tried it on 12V. I did add a thermostat and 2 12V muffin fans to move air through the compartment, I've done that on many RVs in the past with good results. These were added to the rpod within days of bringing it home
2014 179
CharlieM
Posted: 03 Aug 2014 at 1:34pm |
My post was not based on theoretical thermoelectric or absorption technology. It was based on my observation of the Dometic 8501 in my RP172. It reflects not only the technology, but the particular application including unit capacity and box insulation. I wish I could have maintained 40F (4C) with ambient at 95F, but I couldn't. In testing I did use a wireless thermometer to avoid unnecessary door opening, but the fridge was in use. The larger Dometic in my Camplite works better but I attribute that to better design and construction.
Outbound
Posted: 03 Aug 2014 at 1:01pm |
I believe that the 40F differential applies to thermo-electric coolers, not gas absorption.
In five years of owning my r-pod, I've never had an issue. In fact, I haven't touched the thermostat in years - its set to 2 degrees Celsius and reliably stays there (I have a food service thermostat in the fridge) on A/C, D/C or propane.
CharlieM
Posted: 03 Aug 2014 at 11:18am |
What you're seeing is normal per my experience. Overall about 40F delta from outside ambient. There is a lag as it warms up outside and a longer lag as the fridge tries to cool down after a hot afternoon. Propane or shore power about the same, 12V battery not so good. Opening the door is really bad.
Leo B
Posted: 03 Aug 2014 at 10:13am |
I have had that happen when using battery while travelling down south. But never while plugged into power. I know it takes a while for the fridge to cool down when first plugged in.
Elkhart
Posted: 03 Aug 2014 at 10:09am |
plugged in, then propane same result
Keith & Kelly
2012 171 Pod
2013 Ford F150 TV
Leo B
Posted: 03 Aug 2014 at 10:02am |
Were you plugged in or running on battery or using propane?
Elkhart
Posted: 03 Aug 2014 at 9:44am |
The other day when it was in the 90+ deg. range outside the Refrigerator Temp. could only get down to 48 50 deg., but over night the temp when the outside temp fell it went back to 34 deg. I read in one of the treads on this form that a absorption type frig can only go 40deg below ambient(outside temp). if this is true it would explain the temp swing.
Keith & Kelly
2012 171 Pod
2013 Ford F150 TV
