Page <1 234 |
![]() Posted: 07 Feb 2014 at 9:38pm |
True, but only for AC. I needed DC capability for the 12V stuff. I've been using AC current transformers for years and Hewlett Packard even made a DC clamp on back in the 60s, but it was an expensive lab instrument. AC clamp on meters have been cheaply available for years because they're easier to make, but now DC clamp on meters are becoming affordable. Beats the hell out of cutting the wire and inserting a shunt. ![]() Charlie |
I am going to have to investigate the physics of this. An AC clamp on acts like transformer coil and has current induced by the build up and break down of the current going through the sine wave. DC can't induce current because it only has the transition turning on then off. I wonder how the sensing works. Doug, do you get this?
The DC instruments use Hall effect sensors. They can measure both AC and DC and are getting cheaper along with all other semiconductor devices. See these articles for starters:
http://www.powerstream.com/DC-clamp.htm http://www.electrotechnik.net/2009/09/how-does-dc-clampmeter-work.html Charlie |
Thanks!
You can make a cheap DC amp meter using a resistive shunt (a known accurate resistor or length of wire) and a voltmeter. But you can't beat that Sears clamp-on for price and ease of use.
Yep. I thought about using the "calibrated" piece of wire, but with all the Chinese stuff floating around I'm not sure I could count on wire marked 10AWG really being 10AWG. Besides, I needed a new toy
![]() Charlie |
bhamster ![]() Senior Member ![]() Joined: 19 May 2011 Location: Washington Online Status: Offline Posts: 165 |
Charlie- I've got another random question for you about the camplite. What's behind the hatch on the slide out? It seems like some have it and others don't. Is it storage, or some kind of service access panel?
It is a storage compartment. About 8 inched deep and as wide as the slide. Height is a bit more than the door height. Sorry I can't be more specific, but I'm camped at Fort Pickens National Seashore, FL and it's dark and raining outside. The compartment appears to only be available with the dinette option, not the couch. Good added storage. BTW, I'm detecting a growing case of Camplite fever there
Awesome, that's what I was hoping. The more storage the better. I'm assuming you got the dinette then (I thought all RBS models had the couch). Do the dinette side benches lift up for storage on the inside also?
Both 21s can be ordered with either couch or dinette. The dinette seats do not lift for storage. That space is partially consumed by the wheel covers. There is a small bit of unused and inaccessible space, but it's minimal. It could be accessed, but you would have to cut access holes and add bottom shelving. I really don't think it's worth the effort; there's lots of storage space already. Also note, there are no drawers in the camper, just lots of shelves. Drawer space, if desired, requires a trip to the store for plastic containers.
Page <1 234 |
