  New Posts New Posts RSS Feed: Upgraded to Camplite 21RBS
Topic ClosedUpgraded to Camplite 21RBS
Tars Tarkas View Drop Down
Direct Link To This Post Topic: Upgraded to Camplite 21RBS
    Posted: 26 Dec 2013 at 9:35pm
I suppose the thing to do is to follow the hott-rod link, but first, I'm confused about the drain plug.  I suspect Techntrek is correct to interpret that as anode.  Taking that out is probably not the best idea, but I wonder if the hott-rod could include an anode as part of the package.  Smaller, certainly, than the one that was removed, but still workable at least in theory.
Sleepless View Drop Down
Direct Link To This Post Posted: 26 Dec 2013 at 7:00pm
That is a very good point, one that I had not considered before.  I checked the manufacturer's web site and it states that "The Suburban reducer includes a built-in anode."  I did not check any further, so that is all I know about the anode.    http://dg-usa.com/hott-rod/
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 26 Dec 2013 at 6:45pm
One downside with that solution is you are removing the anode rod, so you'll be cutting down on the life of the tank.
CharlieM View Drop Down
Direct Link To This Post Posted: 26 Dec 2013 at 3:16pm
Sleepless,
Very interesting. I've never heard of the Hott Rod. I was able to request a WH transplant from the factory because I special ordered the Camplite. But, for those not so able, your solution is great. Thanks for the info.
Direct Link To This Post Posted: 26 Dec 2013 at 2:59pm
Charlie,  I have only had one travel trailer that came with a propane only water heater.  One of my negotiation points with the dealer was the installation of a Hott Rod.  You are probably familiar with them, but for those who are not, it is an electric  element that screws into the tank's drain plug opening.  They ran the 120 volt line into the cabin along with a 120 volt receptacle near the bottom of a cabinet.  I had to install a switch with an "on" light after I took possession.  The Hott Rod is an efficient accessory items sold in most RV supply stores for under $100.00.  I never had to use the propane heater all the time I owned that trailer.
Bottom line: You can convert any heater to use an electric element.  No big deal.
Direct Link To This Post Posted: 26 Dec 2013 at 11:37am
Mark,
You are correct but I spend a lot of time at home solving problems I don't even have yet. Just the engineer in me. And it even helps sometimes.
The stock WH is gas only. No real issue except
for added redundancy and the cost of propane vs "free" electricity already paid for at the campground. And the gas and electric can run simultaneously for faster shower recovery.
I don't think there is any satisfactory internal probe solution. The Horst probes claim to be better, but
marginally I think. The SeeLevel system works on a totally different principle and is entirely external to the tanks. More $$ but I think it is technically better and it's easy to retrofit, especially since you have the wiring in place.
http://www.rvgauge.com/products/model_709RP.shtml
The city and fresh water filler ports are on the right (curb) side as is the backflusher if ordered. No problem. Just carry more hose and snake it. The shore power, cable TV and dump connections are on the left side.
Camp on,
Direct Link To This Post Posted: 26 Dec 2013 at 10:03am
Charlie,
Thanks for your notes.. I bet the more you camp, the more you notice..
So the "stock" WH is gas only? We could live with that no problem, but good to know to ask for a 2-way.
Interesting the no tank probes.. That has surely been an industry standard for a long long time.. I know for sure Airstream had them as far back as '69.. We have done a bit of research on them, my dad says he has never had a camper with "reliable" gauges.. we plan to switch to these.. LINK
I meant to ask.. is your city water inlet on the street side? It appears you have a hose and filter hooked up on the curb side??
Mark
Direct Link To This Post Posted: 26 Dec 2013 at 8:49am
Originally posted by furpod
Looks Good!
Our dealings with the factory have all been positive.. If I may ask, how much was the shower skylight option? That is the one and only thing not in the regular factory options list we want..
Furpod,
Coming from the RPOD world, a few other convenience items you may want to consider:
Gas/electric water heater: The Suburban SW6DE is a drop in form/fit replacement and just requires 120V wiring. Livinlite even installs a lighted toggle switch inside the camper.
Black tank backflusher: This is a real convenience. For some reason LL is reluctant to provide this as a standard, but almost all other camper lines are going this way. LL did an excellent job installing one for me.
And a not so obvious item: Water tank gauges. The Camplite has no tank level gauges. Even though the ubiquitous internal probe tank sensors are a pain, they are sometimes useful. I am looking at adding the SeeLevel gauge system. It uses external glue on sensors that should be more reliable and can be added without tank removal or drilling.
Enjoy campling,
Direct Link To This Post Posted: 22 Dec 2013 at 1:13pm
Looks Good!
Furpod,
I can't say on individual options. I didn't break them out individually. I think the factory charges a one time engineering charge, but that may include all the requested changes. The skylight was so big and well done that I suspect they had engineered this mod before.
It really makes a difference when standing in the shower. The folks at Littel Campers were so impressed that they decided to order all future units with that mod.
Direct Link To This Post Posted: 22 Dec 2013 at 1:01pm
Looks Good!
