  New Posts New Posts RSS Feed: Riser being installed - any considerations?
Topic ClosedRiser being installed - any considerations?
Itsgr8 View Drop Down
Direct Link To This Post Topic: Riser being installed - any considerations?
    Posted: 08 Dec 2013 at 4:03pm
I bought a 2010 R173 a year ago.  This month, I'm having the axle risers installed.  I've read some of your posts and see that the Dome awning will be affected.  Is there anything else? I want to make sure that I am prepared for the changes.  Thanks in advance!!!
Sleepless View Drop Down
Direct Link To This Post Posted: 08 Dec 2013 at 4:41pm
You will have to raise your hitch ball to match the increased height of the pod coupler.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 08 Dec 2013 at 5:56pm
... unless raising the pod leaves the tongue level or slightly nose-down (either is correct).
Direct Link To This Post Posted: 08 Dec 2013 at 6:08pm
When I installed my risers, it raised the frame 4 inches.  I had to raie my hitch 2 holes (4") to keep the pod level when hitched.  You are right, if the trailer was not level to begin with.
Direct Link To This Post Posted: 08 Dec 2013 at 8:20pm
I had to lower my hitch before to accommodate the r-pod.  I am sure that I will have to raise it if just a little.
2010 R-pod 173
2012 GMC Canyon
GaRedneck81 View Drop Down
Direct Link To This Post Posted: 16 Dec 2013 at 10:24pm
Your step will also be affected.
GaRedneck81
USN Retired
RP-172
Podsible Dream View Drop Down
Direct Link To This Post Posted: 20 Dec 2013 at 9:28pm
You might want to use some 4x4 blocks to raise the front ends of the dome long pole.  That will raise the dome to a level condition.  The side grey panels are a bit short but at learnt the dome is level.
Chris and Walt
'10 RP-171 'Free Spirit'
