  New Posts New Posts RSS Feed: air tabs
Topic Closedair tabs
Sleepless View Drop Down
Direct Link To This Post Topic: air tabs
    Posted: 03 Sep 2013 at 3:13pm
To me, much of the R-Pod's design problem is the backward slope of the lower part of the front.  Bring the front down perpendicular to the road and I bet mpg will improve.  Again, this is just me thinking out loud.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Seanl View Drop Down
Direct Link To This Post Posted: 03 Sep 2013 at 2:53pm
I think although I have never tested it in any way that a lot of the issues with drag on the Rpod is the distance between the TV and the RPod nose. The rounded nose of the pod would create a space between the TV and Pod that would create turbulence that would increase drag. I know that in Tractor Trailers they put fairings on the tractor to reduce the gap between the tractor and the trailer to get more laminar flow across the whole rig. I have thought that maybe the tabs on the back of the TV or both might work better.
Direct Link To This Post Posted: 03 Sep 2013 at 1:12pm
If I had time to kill I would try to rig up a "tail" like this guy did for his car, to see if that smoothed out the rear airflow enough to help with mpg.  This guy achieved a 15% increase.
Alternatively I would like to rig up a triangle that would essentially convert the rear of the pod to a standard camper's boxy rear, to see how that changed things.  In either case the pod's hitch could be used to support the weight, along with two straps over the top running to the tongue to pull it tight and provide more support.
rex View Drop Down
Direct Link To This Post Posted: 02 Sep 2013 at 9:35pm
Air tabs been using them for several months have not been a long trip until past week went on a 550mile round trip,and averaged .4 miles per gal increase,on a long haul say 1000 miles or more its a little savings, the tabs almost stop the pushing effect or sway when being passed by bigger truck,rear of trailor stays cleaner you can see the swirl behind you when pulling in the rain,I USED a total of 32 tabs,16 ea side bought 5 extra,just in case total cost $114.42,w freight.Ea tab costs $2.75. HOPE this is helpful and you can understand me. thanks
jrr
Paige View Drop Down
Direct Link To This Post Posted: 01 Sep 2013 at 9:51pm
Me too!
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Direct Link To This Post Posted: 01 Sep 2013 at 9:48pm
I'll be interested in seeing the long-term results.   :-)
rex View Drop Down
Direct Link To This Post Posted: 01 Sep 2013 at 8:53pm
I hope all can see them botton of picture is a slide not to good at adding pictures, Just got back from a trip, lots of rain you can see back is not to dirty,tabs help that, will let all know about fuel savings when my son get all the numbers.
jrr
rex View Drop Down
Direct Link To This Post Posted: 01 Sep 2013 at 8:45pm
jrr
