morningstarrising
Topic: cable stud Posted: 13 Mar 2013 at 11:00pm |
Thank you Goose
Goose
Posted: 13 Mar 2013 at 10:17pm |
Glad that you got it to work. Now it's time to destress and relax. Goose
morningstarrising
Posted: 13 Mar 2013 at 9:06pm |
Yes thank you as we got it to work. We on the inside connected to the tv stud and you MUST have the Red Light turned Off so it will program correctly when you auto tune for the cable that's piped in if that's the case. If not the Red Light must be on to tune it if you are Not hooking up to any external cable connections. Halleujah!
Posted: 13 Mar 2013 at 6:54pm |
Make sure that the cable is connected to the TV. Ours came loose once while traveling.
2011 R-Pod 177
2010 Ford F-150
Goose
Posted: 13 Mar 2013 at 5:56pm |
Thanks furpod for the picture, that's worth a thousand words. In our case only the Sat. connection on the outside of the trailer is the only one that works. Goose
Posted: 13 Mar 2013 at 4:42pm |
Inside the trailer, possibly behind your television, should be a panel that looks like this:  You need to be hooked up to the one for "sat/aux"... If you are, try hooking up to the other, they could be wrong on the back of the interface. But whichever gives you TV from the antenna, the other is hooked up to the outside feed. EDIT: also, and I think this is what Goose is pointing out, (and I thought I had a picture.. but can't find one).. even though there are TWO connections on the outside of the pod, only ONE of them is actually hooked up. Try switching out there also.
Goose
Posted: 13 Mar 2013 at 3:03pm |
I am reading what you wrote but it sounds like you did not plug it into the Satelite connection at the trailer, please try that because that is the only way that we receive cable from the campgrounds. Goose I know how disappointed you are because we had the same issue when we first got our trailer and I did not want to pack up to go find a dealer to repair it. After sleeping on the problem all night I tried hooking to the Sat. connection and made sure the the line to the television was hooked from the tv to the Cable/Sat stud in the cabinet. We had not had any issues since. Good luck.
HuronSailor
Posted: 13 Mar 2013 at 1:28pm |
Here I thought this thread was about a show on television about me.
Bam!
morningstarrising
Posted: 13 Mar 2013 at 11:41am |
we tried everything and it still wouldn't work from the on-site cable box to our external stud that's named cable tv Not satelite. We do auto channel to pull up the channels and get some but NOT the free cable from the camp grounds that comes with the price paid for the site. We asked the site to check their connections and they work and he said just bypass your external stud to see if you can access our cable so we did and bingo it worked but we still MUST be doing something wrong. Can anyone PLEASE Help so we don't have to take it in to a dealer (far and few between) to take a look at something I am just not up to speed On. Thank you Kindly! Mark& Carol James
Posted: 12 Mar 2013 at 1:56pm |
Here I thought this thread was about a show on television about me. |
Groan. Why didn't I think of that?
Thank you, thank you. I'll be here all night. And the next night, and all next week. Don't forget to tip your waitress!
