Page 12> |
![]() Posted: 29 Oct 2012 at 7:10pm |
Please don't take this wrong, but "dealers" are in fact often, wrong. Do you have an owners manual? If so turn to page 4-27. If not follow this link, and read page... 4-27. |
Dez ![]() Newbie ![]() Joined: 27 Oct 2012 Online Status: Offline Posts: 5 |
It is a 2009. I contacted the dealer to confirm towing capacity.
What year is it? Everything I find says the towing capacity should be 2000 without "towing package" and 4500 with..
Yup, you are all set. I highly recommend a WDH as Sean mentioned above, it will improve your ride quality.
Thanks - good to know.
Seanl ![]() Senior Member ![]() ![]() Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
That is a lot more power than my jeep and the tongue weight max is more than you need. You might find you need a Weight Distribution Hitch being that close to you max towing capacity but I don't think you will have any problems.
I did a little more research and talked with my dealer and the horsepower is actually 288 hp. Towing capacity is 3500 lbs and tongue weight max is 400 lbs. I think this sounds OK for towing a 177 but wanted to get some opinions.
Thanks. Dez |
You are probably on the lower end of acceptable. My Sienna had 215 horsepower and we towed our pod from Maine to Florida - but those trips also showed me that it was underpowered to deal with strong headwinds even on flatlands.
Towing capacity is 3500 . Hp is 240 v6 engine. Don't know torque.
Welcome. What is the horsepower and torque for your engine? What is the towing capacity?
Page 12> |
