Page <1234> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6434 |
![]() Posted: 13 Dec 2018 at 1:31pm |
The dealer ordered the same axle as the original. I would have preferred upgrading. When I get it back, I will look and see if there is a way to make a bracket that would brace the parts of the axle between the mounting bracket and the arms that would be bolt-on and not require welding.
Wood River Pod ![]() Senior Member ![]() ![]() Joined: 30 Sep 2016 Location: Wood River, ID Online Status: Offline Posts: 153 |
SH, did you replace with the same axle as original? Or did you beef it up to the next weight class? I think the next Lippert up is 4,500 or 5,000.
Thanks Jeff
Thank you. My dealer ordered the axle already. It is likely that another Lippert axle was ordered. I will email and ask.
SH,
Just a comment. I have a Dexter axle. Some time ago I was on phone with etrailer and they told me the Dexter axle is more reliable. I have also seen some talk about Lippert and Dexter being one and the same. I can't verify that. Maybe someone else can. I have had more than one person tell me if you have a failed Lippert replace it with a Dexter. The brake and wheel parts are compatible. |
SH,
I was thinking about my old racing days. We would attach ladder bars, traction bars or support beams to the axles and then to the frame. Basically to square the axle under torque. Issue with Pod is you probable shouldn't weld to the axle. You can weld to the frame, but I was thinking about a bolt on solution. You could mount outside of present mounting areas and then back to frame. It may possibly add support outside of the present mounting area. I agree you got a non-answer from Lippert. I'll look at it and offer advice. |
Roger & Joan,
What was the ultimate outcome of your axle, brake, suspension issue? Hope you got everything fixed okay.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2710 |
It should be possible to put an inverted support cradle over the axle that is attached to the frame. You would only have to weld the part that attaches to the frame, and the part that extends over the outer part of the axle would just "wrap" over the top. This would probably increase the load capability of the axle by several hundred pounds without any modifications to it at all.
Well, I got the answer from the dealer. Lippert sent a non-answer answer to the measurements: Begin quote: Thank you for
providing the information. It is possible the axle beam is somehow bent.
The customer may need to replace the axle beam. Based on the DOP of the
unit is out of warranty. Because the unit is 2 years out of warranty I
will not be able to assist with this issue. End quote. It frustrates me that the person who replied could not say it was or wasn't based on the measurements sent by my dealer. The bottom line is that I will be replacing the axle. I view this as a Forest River design flaw. The supports for the axle should be closer to the wheels. Then the road forces would be less able to exert excessive force on the axle. I saw one YouTube video where a shop welded extended mounting brackets to the outside of the frame on both sides to provide a mounting point closer to the wheels. However, I expect that the axle that will replace the one that is on there will be of the same type that is already there and will be subject to the same forces that bent the first one.
The dealer said measurements were sent to LCI. I have not yet heard the results. I suspect a new axle may be in our 'Pod's future.
As usual, YMMV.
Page <1234> |
