  New Posts New Posts RSS Feed: Best way to control dust & mice?
Topic ClosedBest way to control dust & mice?
Direct Link To This Post Topic: Best way to control dust & mice?
    Posted: 19 Oct 2015 at 11:24am
Keith's suggestion is the best - use expanding foam to fill all the holes you can find.
john in idaho View Drop Down
Direct Link To This Post Posted: 19 Oct 2015 at 10:56am
We pull our pod on dirt and gravel, and don't seem to have a big dust problem.  I do have mud flaps on the back of the pickup which helps with the gravel.  Mice -- so far no problem .  We keep the pod in a barn during the winter.
RpodFever View Drop Down
Direct Link To This Post Posted: 18 Oct 2015 at 7:13pm
Thank you for reply & sorry for any confusion. I did not want to go 4x4ing. I only need to drive my truck & Rpod down secondary gravel roads access our location. (Assume Rpod can handle gravel roads).
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 18 Oct 2015 at 2:00pm
FWIW Pods are not off roading devices, even the Hood River edition.  If they bounce to much, like any other towable not built for off roading, they will give you lots of hours of amusement fixing things.
On mine I went underneath with Great Stuff and filled around pipes and wires.  So far no dust, no mice (knock on wood).  That's over 5 years.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Hayduke View Drop Down
Direct Link To This Post Posted: 18 Oct 2015 at 1:48pm
This doesn't answer either of your questions, but I think it's worth putting out there:  the Rpods are NOT easier to pull nor do they provide better towing mpg.  They pull the same as any other camper of that height and weight.  There is some argument to be made that the shape of the Rpod actually decreases mpg by causing more turbulent air
2012 177 HRE
2017 Tacoma Double Cab
Direct Link To This Post Posted: 18 Oct 2015 at 1:27pm
Hello. We are looking at Rpod because assume tear drop easier pull & better mpg. We travel back roads with gravel & dust. We stay back country without paved camp stalls.
Questions: 1) Have owners found best spots & method to add extra weather striping to control dust?
2) Have owners found best spots to add small screens or chalking to stop mice?
Thank you. John. Js123Traveller@Gmail.com
