kymooses
Topic: Beeping Fridge Fix Pictures Posted: 30 Aug 2015 at 2:42pm |
Originally posted by GLBCamper
Actually, when I took the light cover off, my wires go from the connector shown in the picture directly into the side of the fridge through a small hole with a gasket around it. Not sure if Dometic has different models or what. I put a bit of dielectric grease on the connection as long as I was in there and will call it good (I hadn't had any problems. But why wait until the middle of the night to find out!) |
There are a lot of different models yes, so this could be differently run in many of them. Some don't even have these wires at that location but they entire from behind the panels themselves.
GLBCamper
Posted: 29 Aug 2015 at 12:56pm |
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Leo B
Posted: 29 Aug 2015 at 8:55am |
Ah important decisions  that's like cut bait or shrimp? bottles or cans?
kymooses
Posted: 28 Aug 2015 at 9:12am |
It should. Your biggest decision is to either go with white, or clear. |
Posted: 27 Aug 2015 at 2:23pm |
GLBCamper
Posted: 27 Aug 2015 at 11:27am |
Sorry to keep sounding like an idiot, but will any silicone caulk do?
Old: 2014 177 HRE
2016 F150 4x4 Sport
Posted: 27 Aug 2015 at 9:26am |
I understand the argument for simplicity. Cheaper and faster for dealers and owners to fix so the symptom goes away.
But I think the root cause is that huge hole. Not to mention it is counterproductive, especially with an RV fridge, to have a hole in it letting in warm air. Especially in the rear where the hottest air is.
kymooses
Posted: 27 Aug 2015 at 9:08am |
Based on info posted here recently, shouldn't the aluminum fins also be removed to see if there is an air gap behind them, and then seal that area if there is? |
Dometic and Forest River both say 100% this is all that is needed.
I get what you're saying and I myself would probably find the initial entry point where the wires even come in and seal that hole, but I think they wanted to make this something easy owners could do at home in a few minutes.
GLBCamper
Posted: 25 Aug 2015 at 12:36pm |
What type of silicone is best? Just door & window caulk?
Old: 2014 177 HRE
2016 F150 4x4 Sport
Posted: 25 Aug 2015 at 11:34am |
