  New Posts New Posts RSS Feed: Installed new 15amp protected circuit
Topic ClosedInstalled new 15amp protected circuit
Direct Link To This Post Topic: Installed new 15amp protected circuit
    Posted: 10 Aug 2015 at 11:19am
Nice job.  Popups sometimes do something similar by running an extra extension cord out through the canvas to the 20 amp plug on the power pole.
hammockmadness View Drop Down
Direct Link To This Post Posted: 10 Aug 2015 at 10:00am
I like to say I now have 45amp service.  I could have wired it with a 20amp outlet and wiring but didn't think I would need it.
Dana & Regina
Fleetwood & Jasper
2014 181-G
2014 Silverado 4X4
SNO4ME View Drop Down
Direct Link To This Post Posted: 10 Aug 2015 at 8:20am
Nice job!   Thumbs Up
The first known almost 50 amp Pod!
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
Direct Link To This Post Posted: 10 Aug 2015 at 8:13am
Really nice work!!
Direct Link To This Post Posted: 10 Aug 2015 at 7:44am
  Great job! Looks like a professional electrician did the work.
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 10 Aug 2015 at 7:08am
I got tired of resetting the main breaker every time we used a heavy wattage appliance while the AC and water heater were on, so I installed a separate 15amp, 120v protected circuit in the kitchen slideout.  Here are a few pictures...
The new outlet is on top with the ice maker and electric tea pot plugged into it...
I removed the microwave/convection oven for access.  We may just leave it out for additional storage.
The new outlet is in the blue box, just below the one that is in the cabinet above the sink for the microwave.
The rest of the circuit was installed in the refrigerator cabinet from the outside of the slideout.  I installed a small breaker box with a 15amp breaker to the floor of the refrigerator cabinet.  All of the wiring was zip tied away form the heat of the refrigerator exhaust.
The feed wire for the outlet goes straight up through the bottom of the microwave cabinet and is zip tied away from the heat of the refrigerator exhaust.
The inlet for the circuit is just above the lower refrigerator vent to the right.  I keep a loop zip tied to the end of the heavy gauge extension cord to relieve tension on the inlet connector.  The extension cord plugs into the parks 20amp circuit (if they have one).
It may be a little overkill, but I cut a square from on old 1/4" nylon cutting board and screwed it to the outside wall with heavy, coarse threaded stainless steel screws.  The 15amp inlet was then screwed through it and the outside wall with stainless steel screws.  All of the surfaces were sealed with silicon sealer when assembled.  It's not going anywhere.
Dana & Regina
Fleetwood & Jasper
2014 181-G
2014 Silverado 4X4
