![]() Posted: 27 Apr 2015 at 9:25am |
Glad you got it worked out.
R-Pod'nFJ ![]() Newbie ![]() Joined: 04 Apr 2015 Online Status: Offline Posts: 37 |
I got it straightened out. I made it to our RV shop just before they closed and got an dropped shank. I had to drill another 3/4" hole so my head would put the top of the ball at roughly the same height as the Pod's receiver. Once I got it set up the back of the trailer was sitting lower than the front so I had to lower the hitch head one hole anyway, so I wasted time drilling that hole. Oh well, at least I got it setup and just need to torque everything down.
14 Cement Gray FJ Cruiser
15 R-Pod 179 71 Honda CB750 cafe racer project 71 Honda CB350 75 Honda XL350 81 KZ550 Ltd. street tracker project Scott & Kerri |
See this online tool: http://www.equalizerhitch.com/About%20Equal-i-zer/shanksizes.php
My FJ is lifted about 2.5" and with the head on the lowest hole the top of my ball is 21 3/8"-21.5" off the ground. When the pod is level the top of the ball receptacle is about 18 3/8" off the ground. Would a 4" drop hitch shank be all I need?
I might see if Equalizer might accept the original hitch shank that is sent with the kit since I didn't even use it. Maybe give me some money back? I doubt it but it might be worth a shot. |
