Topic: HEATER Posted: 15 Jan 2015 at 7:58pm |
hot news!
hogone
Posted: 15 Jan 2015 at 6:19am |
good to know it wasn't to crazy of a question!!! hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Outbound
Posted: 14 Jan 2015 at 8:58pm |
I've done it - occasionally on purpose (its cold/wet out and I want a warm trailer when stopping for lunch), usually by accident (forget to turn it off when travelling from one campground to another). I've got a programmable thermometer in the trailer, so I tend to just turn on the furnace at the start of a trip and then forget about it.
I've never had any problems. The furnace is DSI, so if the flame doesn't light, it'll shut down the gas. I also tend to leave the water heater on as well.
But, don't forget: before pulling up to a gas pump, always shut down your propane appliances (fridge, water heater, furnace). And, ferries and some tunnels as well prohibit propane usage.
Posted: 14 Jan 2015 at 7:32pm |
I've been down to 8 F, no problem.
I'd say it can't hurt to try the furnace, at the worst it will just shut down. But I agree the wind will likely be a problem.
Podster
Posted: 14 Jan 2015 at 3:59pm |
Like zero? Seriously? I'm going to pass on that, hogone.
Cliff & Raelynn
Ranger 4.0/178
hogone
Posted: 14 Jan 2015 at 2:41pm |
true, but was just thinking if it was like zero out it might be friendlier (don't think I spelled that right) on the hoses/wires etc under the sink and the slide. again no biggy, just curious! hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Podster
Posted: 14 Jan 2015 at 2:27pm |
Probably would not do it only because the POD heats up so darn fast anyway.
Cliff & Raelynn
Ranger 4.0/178
Seanl
Posted: 14 Jan 2015 at 9:53am |
No never done it and I don't know if it will work. I would worry about a draft blowing out the flame. But if it did the saftey should shut down the gas so you did not get a gas leak. I don't know enough about the construction of the furnace.
hogone
Posted: 14 Jan 2015 at 6:49am |
crazy question!!!! has anyone ever turned on there heater on while traveling (say maybe 30 minutes prior to arrival to stopping) so the pod is toasty warm when you get there? it may not even work, or may be totally unsafe, or may be a totally crazy thing to do!!!! never have and probably never will; just curious hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
