  New Posts New Posts RSS Feed: Maintenance on Electricals
Topic ClosedMaintenance on Electricals
Direct Link To This Post Topic: Maintenance on Electricals
    Posted: 12 Dec 2014 at 9:51am
I would just unplug if not using the pod for a guestroom, hideout, man cave etc.. go out and plug in once a month for a day.
Direct Link To This Post Posted: 11 Dec 2014 at 10:24pm
The converter will use about 35 watts 24/7, so over 800 watts each day.  You'll use less using a trickle charger.  Or, charge them every 30 days overnight, then no need for the trickle charger.  If you leave the batteries outside where they will stay cold during the winter you can get away with one charge in the middle of winter.
Luv2Q View Drop Down
Direct Link To This Post Posted: 11 Dec 2014 at 9:30pm
When your Pod is plugged in to shore power, your converter is charging your battery.  I leave ours plugged in but check the battery water level periodically.
Welcome to the group from just up the road (Bryan/College Station).
John & Teri
Tundra 5.7L V8 / RP 180
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 11 Dec 2014 at 9:24pm
 For the Winter, I remove my batteries (I have two) and keep them in my basement throughout the Winter. I charge them using a Norco Genius charger, then leave them until the Spring.
 When getting ready for a trip, I plug into 110V at least two days before my trip so the onboard converter/charger tops them off.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
MikeGranberry View Drop Down
Direct Link To This Post Posted: 11 Dec 2014 at 9:10pm
My Rpod 179  lives  in a 12x24 storage garage with a 110 outlet.
Is it better to plug in the trailer to 110 or put the battery on a 12 volt trickle charge?
Buick Enclave 2014
Rpod 179
Interested in cycling & kayaks
