  New Posts New Posts RSS Feed: mold
Topic Closedmold
Direct Link To This Post Topic: mold
    Posted: 12 Sep 2014 at 9:25am
Just scrubbed heartily.  Since the caulk otherwise has looked fine when I've done my annual inspections I didn't want to mess with it.
kymooses View Drop Down
Direct Link To This Post Posted: 11 Sep 2014 at 9:28pm
Definitely isn't superficial on mine, no amount of washing/scraping will take it off.
have you actually taken a blade and shaved off the top layers?  not saying you should do that, just what i noticed when replacing mine that it doesn't go all the way through.
but i suppose enough neglect and enough time it would penetrate further
Direct Link To This Post Posted: 11 Sep 2014 at 8:21pm
Direct Link To This Post Posted: 11 Sep 2014 at 4:01pm
The mold spots in the caulk is a confirmed "cosmetic" failure only.  It's a bit ugly, but you can alleviate it some with some regular cleaning.  Literally just a micro millimeter of scraping the ugly caulk and there is fresh clean stuff underneath.
You'll see it on a love of RV's on a lot of different RV forums.
Direct Link To This Post Posted: 11 Sep 2014 at 11:13am
Whatever they used on mine molded up fairly quickly.
jeeperic View Drop Down
Direct Link To This Post Posted: 11 Sep 2014 at 10:33am
Welcome.  This is "normal" for the stuff they use at the factory.  I don't agree with it though.
Do you mean its normal for the caulk to mold? Luckily I haven't experienced that. Hopefully strong disinfectant and a pressure washer will help.
That's the power button..press it.
Turn it all off.
Go outside!
'14 RPod 171
'09 Jeep Wrangler JK (mine)
'14 Dodge Ram 1500 4x4 (hers)
Direct Link To This Post Posted: 10 Sep 2014 at 1:48pm
billyb View Drop Down
Direct Link To This Post Posted: 10 Sep 2014 at 10:53am
Bought 2015 model 171. After couple months noticed mold only on exterior in the caulk. Never had this happen on any prior RV I've owned. Tried some black streak remover, did nothing. I'm sure this is only a cosmetic issue but ugly to look at. Anyone else have this happen?
