  New Posts New Posts RSS Feed: Picture help
Topic ClosedPicture help
TerryM View Drop Down
Direct Link To This Post Topic: Picture help
    Posted: 31 Aug 2012 at 4:10am
That last one looks pretty good.  Thanks!
Terrry
Direct Link To This Post Posted: 28 Aug 2012 at 9:40pm
That looks like winner to me.
bhamster View Drop Down
Direct Link To This Post Posted: 28 Aug 2012 at 3:48pm
How about this:
the background is transparent although your browser may show it as white
Direct Link To This Post Posted: 28 Aug 2012 at 2:16pm
I can change the black to non-black pretty easy in Photoshop, but I'm not sure about making it transparent - which is what I believe is needed here.
FuzzySproket View Drop Down
Direct Link To This Post Posted: 27 Aug 2012 at 8:22pm
If all you want to do is remove the black you can open it with MS paint.
Change color1 to white, select the eraser, set the size.
use the slide to change the view (bottom right)
It will take a little time but it's your time, save often and most of all there is an undo button (top right) just in case.
hope that helps,surely not the only or fastest way.
Smile
Tom & Cindy
2010 174 RPod
2013 Ford F250
Direct Link To This Post Posted: 27 Aug 2012 at 7:59am
No, I don't want any background.  The reason is this;  I plan on giving a copy of it to a locale company so they can make a plastic stick-on for the door of my F-150.  I'm sure they can do it but the charge would kill me!
I talked to a place about doing it with paint but they wanted $800.00 to do it!
Terry
Direct Link To This Post Posted: 26 Aug 2012 at 6:18pm
Do you want the black changed to white on the background?
Direct Link To This Post Posted: 26 Aug 2012 at 1:36pm
The biggest thing is removing the background.
Terry
Seanl View Drop Down
Direct Link To This Post Posted: 25 Aug 2012 at 4:56pm
I could but it would depend on what you wanted done whether I had the skill to do it.
Direct Link To This Post Posted: 25 Aug 2012 at 3:29pm
Does anyone have a program that would allow you to make some changes to this picture?
If so I can explain what I want done.
Terry
