Page 12> |
![]() Posted: 15 May 2018 at 7:23am |
+1 to Glueguy. The outlets are the same size to the drain hose fits.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2707 |
Is there that much variability? You made me go out and measure ours. Our gray water drain is 2" OD; probably 1-1/2" ID. The black water tank is 3-1/2" OD; probably 3" ID. The cover plates are 4" on both.
I have a 3" black water drain, and a smaller 2" or less gray drain. I think biggest drain is 3", cover is close to 4".
It's strange that they went with a smaller diameter drain for the gray tank. On our 2016 179, both drains are 4".
Alan
Wood River Pod ![]() Senior Member ![]() ![]() Joined: 30 Sep 2016 Location: Wood River, ID Online Status: Offline Posts: 153 |
Our pull handle to open the drain valve on the gray tank is gray and the black tank is black.
Thanks
NAP1947 ![]() Groupie ![]() Joined: 14 Aug 2017 Location: Ottawa, Canada Online Status: Offline Posts: 72 |
Thank you, crawled under last night to get a better look. Water tank is closest to hitch, then black under bathroom and grey at the rear near the kitchen. The labels on the side are placed wrong.
Now the fun begins.
Susan and Norm
2016 Venza, V6 factory tow 2018 RP179 |
Unless FR has made some major changes in the 179, the tank closest to the hitch (translucent white) is the fresh water tank. Behind that, in front of the axle and underneath the wet bath is the black tank. Behind the axle is the gray tank. It would make no sense whatsoever to have the black tank in the back. How would the toilet flush into it?
We have the 2016 RP179. |
I think if your large pipe, believe 3" does not go to black tank, you have a issue, the smaller drain should in fact go to the gray tank. My 178 is the same as Cranster says, theblack tank is foraward, gray tank is more rear, my freshwater tank is at the aft.
Thanks Crankster, but what does that have to do with the OP?
Page 12> |
