  New Posts New Posts RSS Feed: Battery charging - more newbie questions
Topic ClosedBattery charging - more newbie questions
CharlieM View Drop Down
Direct Link To This Post Topic: Battery charging - more newbie questions
    Posted: 11 Oct 2015 at 5:22pm
I'd say you're good to go. Just check the water and hook up the charger every 2-3 months.
Direct Link To This Post Posted: 12 Oct 2015 at 9:29pm
Nice yard!
jburns View Drop Down
Direct Link To This Post Posted: 26 Oct 2015 at 8:11pm
When you say "hook up the charger" would I be fine just plugging the trailer in once a month to let the battery charge up over the winter? and as the OP suggested do I disconnect one of the leads?
Direct Link To This Post Posted: 26 Oct 2015 at 9:02pm
Disconnect either battery lead at the battery terminal when not charging. Once every two months reconnect the battery and plug in the pod to 120V shore power. Let it charge overnight. Next day unplug the pod and disconnect the battery. Repeat two months later. If you can leave the Pod plugged in all the time you can leave the battery connected. The builtin converter will keep the battery fully charged.
Direct Link To This Post Posted: 27 Oct 2015 at 9:28am
Make that every month in warm/hot months. You can go to every two months in the winter. Self-discharge is too high in the warm months to go more than 30 days.
